Community
cancel
Showing results for
Search instead for
Did you mean:
DDixo2
OPKG update
When trying to update my opkg package using putty I get the following.
root@edison:~# echo "src maa-upm http://iotdk.intel.com/repos/1.1/intergalactic"> /etc/opkg/intel-iotdk.conf
root@edison:~# opkg update
Downloading http://iotdk.intel.com/repos/1.1/intergalactic/Packages.
Downloading http://iotdk.intel.com/repos/3.5/intelgalactic/opkg/i586//Packages.
Updated list of available packages in /var/lib/opkg/iotkit.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/edison/all/Packages.
Updated list of available packages in /var/lib/opkg/iotdk-all.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/edison/core2-32/Packages.
Updated list of available packages in /var/lib/opkg/iotdk-core2-32.
Downloading http://iotdk.intel.com/repos/3.5/iotdk/edison/edison/Packages.
Updated list of available packages in /var/lib/opkg/iotdk-edison.
Collected errors:
* opkg_download: Failed to download http://iotdk.intel.com/repos/1.1/intergalactic/Packages, wget returned 8.
root@edison:~#
I am guessing the address that the echo command sends has been changed but not sure what to change it too.
Community Manager
Hi retrorocket1,
Thank you for contacting us.
The first thing I'd like to confirm is that your Edison has Wi-Fi connectivity. Have you already gone through the Wi-Fi configuration of configure_edison –wifi?
You can check you have Wi-Fi by doing a simple ping to google.com.
After that, go on and try using the commands:
echo "src mraa-upm http://iotdk.intel.com/repos/3.5/intelgalactic/opkg/i586" > /etc/opkg/mraa-upm.conf opkg update
This process can take a few minutes.
Wait for the process to finish and let us know your results.
-Sergio A
DDixo2
I can't remember if i remembered to do it in this particular run, I keep having to reflash cause of random errors, but I do notice the filename is different in the command you gave so I will check that out and get back to you.
DDixo2
I tried that and got, "No such file or directory"
root@edison:~# "src mraa-upm http://iotdk.intel.com/repos/3.5/intergalactic/opkg/i586 http://iotdk.intel.com/repos/3.5/intergalactic/opkg/i586" > /etc/opkg/mraa-upm.conf
-sh: src mraa-upm http://iotdk.intel.com/repos/3.5/intergalactic/opkg/i586: http://iotdk.intel.com/repos/3.5/intergalactic/opkg/i586: No such file or directory
edit: whoops missed echo just a sec
edit2:
Same issue below
root@edison:~# echo "src mraa-upm http://iotdk.intel.com/repos/3.5/intergalactic/opkg/i586" > /etc/opkg/mraa-upm.conf
Downloading http://iotdk.intel.com/repos/3.5/intergalactic/opkg/i586/Packages.
Collected errors:
* opkg_download: Failed to download http://iotdk.intel.com/repos/3.5/intergalactic/opkg/i586/Packages, wget returned 8.
root@edison:~#
Now I don't know if it matters but I am not able to go to the ip adress of the edison via browser. The reason I am not sure it matters is because all of these commands are over wifi so It definitely has a connection.
Community Manager
Hi retrorocket1,
Thank you for your reply.
I don't think that the opkg update problem is related to not being able to go to the IP address via the browser. There's an issue with some of the latest images that don't allow users to go to the IP address using a web browser. We'd still like to confirm that you have a stable internet connection and know what image you're using.
Please, let us know the output of these commands:
ping -c 10 google.com cat /etc/version
We'll be waiting for your response.
-Sergio A
DDixo2
root@edison:~# ping -c 10 google.com
PING google.com (216.58.217.110): 56 data bytes
64 bytes from 216.58.217.110: seq=0 ttl=53 time=33.206 ms
64 bytes from 216.58.217.110: seq=1 ttl=53 time=38.994 ms
64 bytes from 216.58.217.110: seq=2 ttl=53 time=47.802 ms
64 bytes from 216.58.217.110: seq=3 ttl=53 time=42.071 ms
64 bytes from 216.58.217.110: seq=4 ttl=53 time=51.575 ms
64 bytes from 216.58.217.110: seq=5 ttl=53 time=45.911 ms
64 bytes from 216.58.217.110: seq=6 ttl=53 time=56.368 ms
64 bytes from 216.58.217.110: seq=7 ttl=53 time=50.496 ms
64 bytes from 216.58.217.110: seq=8 ttl=53 time=54.391 ms
64 bytes from 216.58.217.110: seq=9 ttl=53 time=49.021 ms
--- google.com ping statistics ---
10 packets transmitted, 10 packets received, 0% packet loss
round-trip min/avg/max = 33.206/46.983/56.368 ms
root@edison:~# cat /etc/version
201606061707
root@edison:~#
Community Manager
With this information we can confirm that the issue is not related to an older image or to Wi-Fi connection.
However, it's strange that you continue to receive that error. Have you made any configurations to any of the files inside /etc/opkg, such as /etc/opkg/base-feeds.conf or /etc/opkg/iotkit.conf? Please let us know the output of these, as well as of /etc/opkg/intel-iotdk.conf.
-Sergio A
Community Manager
Hi retrorocket1,
Do you still need assistance with this case?
-Sergio A
DDixo2
I am actually good now, I found the answer at http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html Edison Package Repo Configuration Instructions and after following its instructions opkg works, I appreciate all the help
Community Manager
Thanks for sharing the solution that worked for you with the community. Feel free to contact us again if help is needed.
-Sergio A
