Community
cancel
Showing results for
Search instead for
Did you mean:
RAtlu1
New Contributor II
OSIP Header compiler - Standalone
Dear Admins
Given that I already have compiled u-boot.bin and u-boot-env.bin and I have rootfs.fat file, how do I use this function python do_osip_mkimage() to calculate and output the OSIP.bin file?
http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-edison/tree/meta-intel-edison-bsp/recipes-bsp/u...
1) Does its calculation depend on the size of the u-boot and size of u-boot-env
2) Does its calculation depend on the size of the rootfs.fat file?
If so what are the various variables needed to calculate the correct OSIP.bin?
It seems the xfstk looks at the osip.bin for determining the correct file size before flashing rootfs file along with the fw files.
xfstk-dldr-solo --gpflags 0x80000007 --osimage output_xfstk.img --fwdnx edison_dnx_fwr.bin --fwimage edison_ifwi-dbg-00.bin --osdnx edison_dnx_osr.bin
Kindly throw light.
We can finish this development of custom OS distros for Edison
Community Manager
Hi Mosfet,
Let me gather some more information and do some tests related to this. I will let you know as soon as I get some more information/results.
Charlie
RAtlu1
New Contributor II
I guess xfstk cant do bulk transfers? May be that is reason why only basic firmware is pushed via xfstk and then edison is bought into dfu mode to flash via dfu-util??
Correct me if i am wrong. But if i burn osimage output_xfstk.img (smaller sized ones which include osip.bin+u-boot.bin+u-boot-env+roofts) it seems to burn okie but for large sized ones it doesn't seem to work.
RAtlu1
New Contributor II
Here is the log for the command (only showing upto the errors part)
xfstk-dldr-solo -v --gpflags 0x80000007 --osimage output_xfstk.img --fwdnx edison_dnx_fwr.bin --fwimage edison_ifwi-dbg-00.bin --osdnx edison_dnx_osr.bin
Please note that ouput_xfstk.img contains OSIP+u-boot+uboot-env0+uboot-env1+rootfs which is about 400MB.
XFSTK-PROGRESS--98
XFSTK-LOG--GetOpCode
XFSTK-LOG--ReadInAck
XFSTK-LOG--GetAck
XFSTK-LOG--GetAck - DIFWI31(0x8)
XFSTK-LOG--WriteOutPipe __BINARY__
XFSTK-LOG--WriteOutPipe 0
XFSTK-LOG--Write --->__BINARY__
XFSTK-LOG--LogProgress
XFSTK-PROGRESS--100
XFSTK-LOG--GetAck
XFSTK-LOG--GetAck - HLT$(0x4)
XFSTK-LOG--FW: Firmware update completed...
XFSTK-PROGRESS--100
XFSTK-PROGRESS--100
XFSTK-LOG--LogError
XFSTK-STATUS--Error Code: 0 - Success
XFSTK-LOG--void MerrifieldDownloader::do_abort()
XFSTK-LOG--Abort
XFSTK-LOG--edison_ifwi-dbg-00.bin size:4194468 bytes
XFSTK-STATUS--PASS
XFSTK-STATUS--Firmware download completed. Continuing to OS...
XFSTK-STATUS--Reconnecting to device - Attempt # 1
XFSTK-LOG--virtual bool MerrifieldDownloader::UpdateTarget()
XFSTK-LOG--FWDnxPath -- edison_dnx_fwr.bin
XFSTK-LOG--FWImagePath -- edison_ifwi-dbg-00.bin
XFSTK-LOG--OSDnxPath -- edison_dnx_osr.bin
XFSTK-LOG--OSImagePath -- output_xfstk.img
XFSTK-LOG--MiscDnxPath -- edison_dnx_fwr.bin
XFSTK-LOG--MiscBinPath -- BLANK.bin
XFSTK-LOG--Gpflags -- 80000007
XFSTK-LOG--DebugLevel -- ffffffff
XFSTK-LOG--UsbDelay ms -- 0
XFSTK-LOG--TransferType -- USB
XFSTK-LOG--WipeIFWI -- False
XFSTK-LOG--Idrq -- False
XFSTK-LOG--Verbose -- True
XFSTK-LOG--void MerrifieldDownloader::Init()
XFSTK-LOG--Open
XFSTK-LOG--Windriver Error: 0x2000000F, Device not found
XFSTK-LOG--Device Vendor id:0, productId:0, NOT FOUND!!
XFSTK-STATUS--Reconnecting to device - Attempt # 2
XFSTK-LOG--Open
XFSTK-LOG--USB Device found - USBSN: AC715B4A5B9F2143004B352B27B8745D Address:4
XFSTK-LOG--void MerrifieldDownloader::do_update(MerrifieldOptions*)
XFSTK-LOG--Start
XFSTK-LOG--Sending DnER...
XFSTK-LOG--WriteOutPipe DnER
XFSTK-LOG--Write --->DnER
XFSTK-LOG--GetAck
XFSTK-LOG--GetAck - DORM(0x4)
XFSTK-LOG--OS: Handle OS download...
XFSTK-PROGRESS--11
XFSTK-LOG--Changing to DLDR_STATE_OS_NORMAL ...
XFSTK-LOG--CheckFile
XFSTK-LOG--_num OS Images : 1
XFSTK-LOG--_temp_data : c0000
XFSTK-LOG--OSII: 0 Data Size: 402653184
XFSTK-LOG--_Temp Data is: c0000 h
XFSTK-LOG--InitOsipHdr
XFSTK-LOG--Init OSIP header ...
XFSTK-LOG--_After fread osip_hdr
XFSTK-LOG--InitOsDnX
XFSTK-LOG--edison_dnx_osr.bin size:148996 bytes
XFSTK-STATUS--POS download is in progress ...
XFSTK-LOG--StartOs
XFSTK-LOG--sending 6 DWORDS of DnxOS size and checksum...
XFSTK-LOG--GetOsDnXHdr
XFSTK-LOG--WriteOutPipe F
XFSTK-LOG--Write ---> F
XFSTK-PROGRESS--22
XFSTK-LOG--End of MrfdStHandleOsNormal
XFSTK-PROGRESS--33
XFSTK-LOG--GetAck
XFSTK-LOG--GetAck - DXBL(0x4)
XFSTK-LOG--OS: Sending DnX ...
XFSTK-LOG--OsDXBL
XFSTK-PROGRESS--44
XFSTK-LOG--GetOsDnX
XFSTK-PROGRESS--55
XFSTK-LOG--GetAck
XFSTK-LOG--GetAck - ROSIP$$$(0x8)
XFSTK-LOG--GetOsipHdr
XFSTK-LOG--Get OSIP header + Partion Table...
XFSTK-LOG--sending OSIP...
XFSTK-LOG--sending OSIP header + Partion Table...
XFSTK-PROGRESS--66
XFSTK-LOG--GetAck
XFSTK-LOG--usb_bulk_read() fails
XFSTK-LOG--Windriver Error: 0x20000015, Timeout expired
XFSTK-LOG--Device is not responding...
XFSTK-LOG--GetAck - (0xBAADF00D)
XFSTK-LOG--LogError
XFSTK-STATUS--Error Code: 4 - Error attempting to read ACK/NACK from IN Pipe
XFSTK-STATUS--Unknown Ack code:0, aborting ...
XFSTK-LOG--Abort
XFSTK-STATUS--FAIL
XFSTK-STATUS--Errors encounter during OS download. Aborting ...
RAtlu1
New Contributor II
can we do something about the Timeout? Is there an option for have large timeouts for large files?? I dont see that option...i tried usbdelayms but that doesnt seem to help
Community Manager
Hi Mosfet,
I'm still working on this, thank you for the full log. I also would like to know if there is something else you have tried that we should consider too.
I will see if there is a flag that we could use for setting the timeouts.
Charlie
RAtlu1
New Contributor II
I dont have anything else Charlie. I am waiting for a solution from you guys....
Community Manager
Hi Mosfet,
I've been investigating to help you with this, unfortunately this hasn't been validated yet so there is no more information regarding to it.
-Charlie
