Hello!
I want to upgrade the firmware on my Intel Edison by hisself.
The old way is to copy the extracted files from the downloaded archive to the virtual USB Flash Drive (Edison).
Then you need to run "reboot ota" over ssh or serial connection and the upgrade is going to start (without the help of a computer).
Because the firmware is too big (> 1.4 GB) for the virtual Flash Drive (768 MB)
today, you start the firmware upgrade from the computer by running the script "./flashall.sh"
But i want to update the edison without a computer.
I tried to copy the compressed zip image to the virtual usb drive and run
configure_edison --flashFile
but it didn't workd (an error something like "Cannot setup loop device" occured)
Then i tried do run directly
configure_edison --upgrade
but it also cancled with error:
Could not determine firmware version information.
Could not upgrade device firmware. Quitting.
list index out of range
Do anyone have an idea how to upgrade edison firmware without a computer?
Thank you very much!
Best regards
PS: Sorry for my bad english
PPS: To say it short: I want to do a firmware upgrade without a computer, just per remote connection and if need: per external flash drive (like usb stick or sd card).
Because later, i want to put it in a case that isn't openable.
- Tags:
- Upgrade PC
Hello pelzfrucht,
I've an idea that might be able to help you but you will have to build your own image and strip it from all the packages that are not required in your project. If you do so, you will be able to build an image that is shorter in size and you'll be able to inset it into the Edison's drive. If you would like to learn how to build a Yocto image and how to modify it, I'd suggest you to read the following documents:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005616.html
http://www.yoctoproject.org/docs/1.7.2/mega-manual/mega-manual.html
Once you have created an image that both fits your needs and is able to fit in Edison's drive, you will have to create a similar method of updating to "configure_edison --upgrade". I mean, as you mentioned, there was a method of updating the image that was similar to an over the air (OTA) update. Since you would like to update the Edison through a remote connection I'd suggest you to read this section of "configure_edison". You can find the source file of configure_edison in /usr/bin/configure_edison.
I hope this information helps.
-Peter.
Hello pelzfrucht,
-Peter.
Hello pelzfrucht,
Do you have any updates for this case? Do you still need help?
-Peter.
Hi Peter,
thank you!
Sorry. I forgot to answer because I am currently at holiday and I am back next week.
But the idea looks good and i am going to try it next or after next week.
Best regards
Alexander
