before start, i apologize my bad English.
in edison,
- cd opt/iotivity
in this directory, i can execute some iotivity example, (simpleserver, simpleclient...)
and i try to setup 'Intel® System Studio IoT Edition' for windows, and import iotivity 1.1.0. but it has many errors.
is that right way to modify iotivity code?
if it's not, what kind of IDE is right way to coding iotivity?
i want to build or modify iotivity code.
thanks.
Hello micael17,
If you are able to run the examples of iotivity directly on Edison, then that means that the library is working just fine. You shouldn't require any additional packages or anything like that on Edison.
Nevertheless, if you would like to use the same code on ISSM, you will have to add the library to the IDE so it can find when compiling it. You can learn how to add libraries to Eclipse (ISSM is based on Eclipse) in http://www.oxfordmathcenter.com/drupal7/node/44.
-Peter.
Hi micael17,
Do you have any updates about this? Do you still need help?
-Peter.
