Community
cancel
Showing results for
Search instead for
Did you mean:
LLuca7
Ostro OS don't boot/connect via serial
I installed the ostro OS for quark on a SD card to use on my galileo gen 2, but I think it isn't booting or something is happening that I can't connect via the serial terminal. It stays forever on the "Connected" state.
My suspicions are:
1- I didn't download the proper Image (ostro-image-noswupd-intel-quark-2016-05-02_00-09-47-build-440);
2- The baud rate is wrong (on their https://ostroproject.org/documentation/howtos/booting-and-installation.html# galileo-gen-2 guide the suguest 115200).
Anyone have any idea? The project is stucked by this.
Thanks!
FTinetti
Honored Contributor I
Hi lucas_hms,
Did you ask to OSTRO OS people/site/forum?
LLuca7
I tried to get in touch with them via the IRC channel, but got no response.
I don't need to use necessarily this OS for the board the. Main features I need are JRE 8/JDK 8 and the MRAA libs to use with java. I'm currently using an Debian version, but I'm having lots of problems to install MRAA
FTinetti
I think mraa is installed by default in yocto (if not, it should be very simple to install, since many people are currently using it), and there are some pages indicating that it's possible to install Java JDK, but I've not checked...
http://thelinuxfaq.com/473-yocto-how-to-install-java-jdk-in-intel-edision-board http://thelinuxfaq.com/473-yocto-how-to-install-java-jdk-in-intel-edision-board
HTH,
Fernando.
PMora5
I tried this version of Ostro OS too and it hangs on boot process (I've connected the Galileo with FTDI cable).
[Firmware Bug]: ACPI: No valid BIOS _PSS frequency found for processor 0
Freeing unused kernel memory: 632K (ce819000 - ce8b7000)
Write protecting the kernel text: 7580k
Write protecting the kernel read-only data: 2008k
random: udevd urandom read with 3 bits of entropy available
IMA: policy update completed
JBD2: no valid journal superblock found
EXT4-fs (mmcblk0p3): error loading journal
Did somebody successfully run Ostro on Galileo?
