Community
cancel
Showing results for
Search instead for
Did you mean:
BMarc4
PC Stick - SC1 not booting
I have an Intel PC Stick SC1 that was working fine a week ago but now it does not want to load at all.
All i am getting is a flashing light on the front of it. Assuming it was in sleep mode i have tried waking it up but with no success.
I have unplugged it and tried it on different screens using different power outlets.
Sorry if there is another thread with the same issue, i did have a look but did not find it. I also tried using troubleshooters.
Community Manager
Thank you for contacting the Intel community.
I'm sorry for the issue you have experience with the Intel® Compute stick, in this case, if you press and hold the power button for three seconds and release it at the 4 second do you get a menu screen? If so, we can try a BIOS recovery to see if that can help.
You can download the latest BIOS version for your Intel® Compute stick here:
https://downloadcenter.intel.com/ https://downloadcenter.intel.com/
Please see https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005902.html BIOS Recovery Instructions for Intel® Compute Stick
If the issue persists, I suggest you to https://www.intel.com/content/www/us/en/support/contact-support.html# @4 contact support to get a replacement for the unit.
Please let me know how it goes.
Ivan U.
BMarc4
Unfortunately this does not work. I have also tried holding the power button in longer to force a shutdown but it does not work. I can only assume it is because it did not boot up to begin with. Even unplugging it and leaving it for a while (left for up to 30min at one point) doesn't change a thing. As soon as i plug it all back in i instantly get the blinking light.
I'm starting to think it may have been hit with a power surge and is now bricked. Just hoping there may be something i can do.
Community Manager
Thank you for the information you kindly provided. Being that the case, I suggest you to request a replacement for unit; you can submit a request here:
https://www.intel.com/content/www/us/en/support/contact-support.html# @4 https://www.intel.com/content/www/us/en/support/contact-support.html# @4
You can do an online service request or you can do live chat.
Ivan U.
