Intel® Makers
9882 Discussions
PCI problems after custom build
DFitz4
have built new kernel and have the galileo board all working and booting up.
uname -a
Linux quark 3.14.28-ltsi-yocto-standard # 1 Mon Mar 28 17:51:30 AEST 2016 i586 GNU/Linux
Using BSP_Sources_and_Docs_for_Intel_Quark_v1.2.1
I have tried looking at dmsg output, lspci, lsmod, etc, but nothing is showing up for the PCI card.
i can't see any detection on the pci bus that an intel wifi card is detected or in dmsg output either (i have that plugged on the board also).
lspci gives me:
00:00.0 Class 0600: 8086:0958
00:14.0 Class 0805: 8086:08a7
00:14.1 Class 0700: 8086:0936
00:14.2 Class 0c03: 8086:0939
00:14.3 Class 0c03: 8086:0939
00:14.4 Class 0c03: 8086:093a
00:14.5 Class 0700: 8086:0936
00:14.6 Class 0200: 8086:0937
00:14.7 Class 0200: 8086:0937
00:15.0 Class 0c80: 8086:0935
00:15.1 Class 0c80: 8086:0935
00:15.2 Class 0c80: 8086:0934
00:17.0 Class 0604: 8086:11c3
00:17.1 Class 0604: 8086:11c4
00:1f.0 Class 0601: 8086:095e
01:00.0 Class 0280: 8086:08b1
which to me seems like nothing has been detected on the pci bus.
one other strange thing is that the lspci version or whatever it is i have, doesn't seem to have the normal lspci options from linux. see below:
root@quark:~# lspci --help
BusyBox v1.22.1 (2016-03-28 18:15:41 AEST) multi-call binary.
Usage: lspci [-mk]
This is really strange. No idea what BusyBox is, etc.
Please help - thanks!
Daniel
DFitz4
ok, so BusyBox is a utility for embedded linux that includes a bunch of known commands.
the full output (using -k option) is below for lspci
root@quark:~# lspci -k
00:00.0 Class 0600: 8086:0958 iosf_mbi_pci
00:14.0 Class 0805: 8086:08a7 sdhci-pci
00:14.1 Class 0700: 8086:0936 intel_quark_hsuart_dma
00:14.2 Class 0c03: 8086:0939 pch_udc
00:14.3 Class 0c03: 8086:0939 ehci-pci
00:14.4 Class 0c03: 8086:093a ohci-pci
00:14.5 Class 0700: 8086:0936 intel_quark_hsuart_dma
00:14.6 Class 0200: 8086:0937 stmmaceth
00:15.0 Class 0c80: 8086:0935 pxa2xx_spi_pci
00:15.1 Class 0c80: 8086:0935 pxa2xx_spi_pci
00:15.2 Class 0c80: 8086:0934 intel_qrk_gip
00:17.0 Class 0604: 8086:11c3 pcieport
00:17.1 Class 0604: 8086:11c4 pcieport
00:1f.0 Class 0601: 8086:095e lpc_sch
still not looking like it's detecting the wifi card on the PCI bus. Nothing on the dmesg as my previous post. I'm really struggling here with this. Any help for me to sort out the PCI properly from the build I mentioned above I would really appreciate.
Some other information is that my system is booting from the following grub menu config:
title Quark X1000 kernel-MassStorage initrd-MassStorage RootFS-MassStorage IMR-On IO-APIC/HPET NoEMU debug
root (hd0,0)
kernel /bzImage root=/dev/ram0 console=ttyS1,115200n8 earlycon=uart8250,mmio32,$EARLY_CON_ADDR_REPLACE,115200n8 reboot=efi,warm apic=debug rw LABEL=boot debugshell=5 rootimage=image-full-quark.ext3
initrd /core-image-minimal-initramfs-quark.cpio.gz
thanks
Daniel
DFitz4
update: the last line of the lspci output i believe actually is the card (starting with 01:00.0)
Pablo_M_Intel
Hi DanielFitzgerald,
Is it working now? Why don't you try to enable the WiFi in your board to determine if the card is indeed being recognized? Have you tried that before?
For instructions on this, follow this guide: https://software.intel.com/en-us/get-started-galileo-linux-step4 https://software.intel.com/en-us/get-started-galileo-linux-step4.
Pablo
DFitz4
Hi Pablo,
No it's not working. Not sure if you read my post or my other post correctly.
I tried the very simple steps at the url you provided and here's the output:
root@quark:~# connmanctl
connmanctl> enable wifi
Error wifi: Method "SetProperty" with signature "sv" on interface "net.connman.Technology" doesn't exist
connmanctl> services
connmanctl>
so no output on "Services" and the error as above. the pci -v output is:
root@quark:~#
so the last line i think detects the card but there is not output of "intel wirelss device"... or anything like that.
there is something wrong.
Pablo_M_Intel
Hi Daniel,
Have you used any of the default images provided in the Download website? I would like to know if you're having this issue with every image you use or only with your custom build. Also, could you please provide the changes that you made to your kernel? We would like to see if there's something specific triggering the issue with the PCI driver.
Pablo
DFitz4
Hi Pablo,
Yes I've used the latest default SD card images provided by Intel (search for my other post) but there's MORE issues with that. The kernel is so old (3.8.7) and doesn't support the latest wifi cards.
With the intel image i can see the wifi card detected on the PCI, but the kernel module can't load the latest firmware (refer other post).
If i use a later kernel from the provided intel dowload links (linux v3.14) (all described in this post) and i followed the exact instructions in the document i referenced above, I have the issue i've described here.
only kernel config is as follows (to enable support for the wifi card):
  • Device Drivers -> Network device support -> Wireless LAN -> Intel Wireless Wifi MVM Firmware support
I have been able to get everything working with someone else's linux v3.19 build. Not sure what modifications he did from the standard one.
The point is that the downloads and setup scripts and build provided by latest files from intel and BSP listed above don't work.
Pablo_M_Intel
Hi Daniel,
Unfortunately, not all features have been tested with the most recent kernel releases. The instructions have been written for various embedded devices and as you can see the image builds successfully, but some features might give some troubles like the one you're having now. The document was developed around the Quark SoC, not exclusively around the Galileo board. Kernel 3.8.7 is the one fully tested with the Galileo, so that's the one that will work with every feature of the board.
Regarding your WiFi card, which one are you using? Are you sure that the card is not supported at all by the Galileo board? (Using the 3.8.7 kernel that is)
Pablo
Pablo_M_Intel
Hi Daniel,
Have you kept investigating about the WiFi card or about the kernel implementation?
Pablo
