Intel® Makers
9881 Discussions
POE for Intel® Galileo Gen 2 Board
HHowa
Hi
I intend to install the Silvertel AG9712-FL Module in the Intel Galileo Gen 2.
I will be using a TP-Link TL-POE150SE Splitter.
The splitter will be connected to a non-POE ethernet switch and DC power supply.
Question:
Can I use a 24VDC power supply?
Thank you
Hg
Community Manager
Hi tcrowe,
Thank you for contacting us, we'll be more than glad to help you with your question.
Regarding your board, do you mean powering the Galileo Gen 2 with a 24V power supply? You should not supply any voltage to the board that isn't between 7V and 15V (to the power barrel). So, if you apply 24V directly you'll definitely damage the board. If you are going to use this 24V power supply, you should use a voltage regulator in-between (7V to 15V).
-Pablo
Community Manager
Hi tcrowe,
We're wondering if you have been able to check our reply or if you have any other question related to your Galileo Gen 2 board.
-Pablo
