Are CCU_PVP_PCLK_DIV and pvp_clk_en accessible to developers? Figure 7 Clocking in Detail from Intel Quark SE Microcontroller C1000 Datasheet February 2017 (Document Number 334712-005EN) shows that these are present on the Quark SE C1000 to control the pvp_pclk, however they are referenced nowhere else in the document.
Hi ,
No , we do not have any SW implementation for these currently.
Do you have a specific use case that you require these for ?
-Michelle.
Hi Michelle,
We have been trying to quantify the power consumption and capabilities of the PME for a low power motion detector. Full control over this peripheral would have been helpful.
The information you are requesting is not available in the public datasheet as we don't have software support for it. However it should be just a matter of configuring the below register accordingly. In addition to that we haven't measure the performance of PME at different CLKs.
MEM Offset (00000000) 34h
Size 32 bits
Default 0000_38DDh
BitsAccess TypeDefaultDescription16:1
4
RW/P3'h0Pattern Matching Engine
Peripheral clock divider
(CCU_PVP_PCLK_DIV)
000b: divide by 1
001b: divide by 2
010b: divide by 4
011b: divide by 8
100b: divide by 16
101b: divide by 32
110b: divide by 64
111b: divide by 128
13RW/P1'b1Pattern Matching Engine
Peripheral Clock Divider
Enable
(CCU_PVP_PCLK_DIV_EN)
This bit must be written from
0 -> 1 to apply the value
12RW/P1'b1Pattern Matching Engine
Peripheral Clock Enable
(CCU_PVP_PCLK_EN)
1b: enable
0b: disable
Alex
