Community
cancel
Showing results for
Search instead for
Did you mean:
TMalh
Paho MQTT repository not found
Dear All,
I am trying to build an intel edison image using bitbake, but I am getting this error:
fatal: repository 'http://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git/ http://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git/' not found
while doing:
~/edison-src/out/linux64/poky/meta-intel-iot-middleware/recipes-connectivity/paho-mqtt/paho-mqtt_3.1.bb, do_fetch
Community Manager
What BSP are you using? The recommended BSP is the latest one found here http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonbsp_ug_331188007.pdf http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonbsp_ug_331188007.pdf .
To include Paho-MQTT you have to follow the steps from Section 4 and use IMAGE_INSTALL += "" but the reason why you're getting a repository not found is because paho-mqtt is not in http://recipes.yoctoproject.org/rrs/recipes/2.1/M4/ http://recipes.yoctoproject.org/rrs/recipes/2.1/M4/ . In this case you'd have to follow Section 4.3 specifically to add the Paho-MQTT package. Have you already followed this section?
Sergio
TMalh
Dear Sergio,
Thank you!
I have followed section 2 of such document ("Build an Intel® Edison Image using bitbake"). Since I was not able to download the zip from step 2, I have found the edison-src-ww25.5-15.tgz (should it be?).
During the bitbake of edison-image, do_fetch of Paho-MQTT was failing with repository not found.
I did not followed section 4, because such package was already included... Not that I need it, it just is in the recipes...
Having further searched for the problem, I noticed that eclipse web site does not host the C client of such package.
I have then replaced the SRC_URI in the file ~/edison-src/out/linux64/poky/meta-intel-iot-middleware/recipes-connectivity/paho-mqtt/paho-mqtt_3.1.bb to https://github.com/eclipse/paho.mqtt.c.git githttps://github.com/eclipse/paho.mqtt.c.git ://github.com/eclipse/paho.mqtt.c.git
It was able to fetch, I just do not know if this is the proper solution, or if it is compatible.
Best,
Tiago
Community Manager
Have you had any issues using Paho MQTT after fetching using this method? As I said, the recommended method for adding third party packages is following the steps from section 4.3. If you see any issues with the paho MQTT installation, please report back to us.
Sergio
TMalh
Dear Sergio,
After fetching Paho MQTT I had no issues in compiling or building and flashing the image in Edison.
I must mention, though, that I do not use Paho MQTT, and thus I have not tested it to see if it is working properly.
I understand that section 4.3 should be followed to include third party packages, but I did not added it myself. I have downloaded the BSP document mentioned previously and have only followed section 2. So I imagine that either I was doing something wrong, or MQTT is already included in either BSP or yocto recipes.
Thank you,
Best,
Tiago
xyina
TMalh
Dear Yinan,
Yes!, thank you. As mentioned previously, that fixes the fetching problem!
Best,
Tiago
mgiun
Tiago, did you build 2.1 or 3.0 ?
TMalh
I am using the edison-src-ww25.5-15.tgz bsp, I assume it is 2.1.
mgiun
thks Tiago,
the problem i found is in edison-GPL_LGPL-sources-ww18-15.zip , which is the 2.1 :-(
another problem, another delay...
I'm starting to doubt about continuing develop on this board
TMalh
Have you changed from https to git? from your previous output you have https://github.com https://github.com but it should be git://
Another thing, it could be that the specific source revision could not be found, but I have tried on my and the output error is different and clearly states that was not able to find the source revision.
In my bb file, it is SRCREV = "93a064dbe9fd2fc84b8bb2701e10d2de8004a11c".
So, I think you need to change the SRC_URI to:
SRC_URI = "git://github.com/eclipse/paho.mqtt.c.git;protocol=http \
file://makefile.patch \
Best,
Tiago
VVorn
New Contributor II
Problem persists in 3.5 but the proposed solution of this thread helps
mgiun
I had this problem too.
I was building : bitbake edison-image -c populate_sdk
I modify ~/edison-src/out/linux64/poky/meta-intel-iot-middleware/recipes-connectivity/paho-mqtt/paho-mqtt_3.1.bb, in the way indicated
with 'http://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git/ http://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git/ replaced by https://github.com/eclipse/paho.mqtt.c.git https://github.com/eclipse/paho.mqtt.c.git
but... this did not solve the problem.
the building fails again BUT controlling the MD5 of the new files :
ERROR: No checksum specified for /home/mgiuncato/edison_new_img_v2.1/bitbake_download_dir/paho.mqtt.c.git, please add at least one to the recipe:
SRC_URI[md5sum] = "5787188a9e3c6bb7f5442a14189cf5df"
SRC_URI[sha256sum] = "4fac9fc606844b12265b562c52496b374ddfe97e79d017a80662b84891136deb"
ERROR: Function failed: Fetcher failure for URL: 'https://github.com/eclipse/paho.mqtt.c.git;protocol=https https://github.com/eclipse/paho.mqtt.c.git;protocol=https'. Missing SRC_URI checksum
ERROR: Logfile of failure stored in: /home/mgiuncato/edison_new_img_v2.1/edison-src/build/tmp/work/core2-32-poky-linux/paho-mqtt/3.1-r1/temp/log.do_fetch.15142
ERROR: Task 753 (/home/mgiuncato/edison_new_img_v2.1/edison-src/poky/meta-intel-iot-middleware/recipes-connectivity/paho-mqtt/paho-mqtt_3.1.bb, do_fetch) failed with exit code '1'
Î am still blocked in this issue.
TMalh
mgiuncato,
my exact line is:
It seems that using https instead of git it fails.. So, see that it is git:// and protocol is specified as http and not https.
best,
Tiago
