Community
cancel
Showing results for
Search instead for
Did you mean:
BBOUC2
New Contributor II
Password for Telnet (with Yoctos on SD card)
Jump to solution
Hello all,
I am facing a strange problem with my Galileo.
When I run it without the SD card, I can connect over Telnet (using a sketch launching "telnetd") being root and without password.
When I use the SD card with Yoctos on it, I can not connect via Telnet, because the shell keeps asking me the password for root. I tried everything I had in mind (root, admin, password, etc....)
Here is what I get on the telnet console
Poky 9.0.2 (Yocto Project 1.4 Reference Distro) 1.4.2 clanton
clanton login: root
Password:
Login incorrect
clanton login: root
Password:
Login incorrect
clanton login: root
Password:
Login incorrect
clanton login: root
Password:
Login incorrect
so the question is very stupid and simple : what is the password for Telnet ?
(Yes, I know that I can use SSH... and it works with SSH without any password. But I hate to find this kind of things and no knowing why it does not work )
Benoit
Diego_V_Intel
Hello BenKissBox,
I've just connected to Galileo's terminal via Telnet with no issues. Could you please let me know how you connected via Telnet?
Please check below the steps I did to connect via Telnet:
  • Then, based on this thread: , I ran the following commands in the console session:
telnetd -l /bin/sh
ifconfig eth0 169.254.1.1 netmask 255.255.0.0 up
  • At this point the eth0 interface should be configured. You can run the command ifconfig eth0 to make sure the IP address and the netmask were set properly.
  • Open another PuTTY session and connect via Telnet. Use the IP address that you just entered to configure the eth0 interface. You should get access now. Check the screenshot below. I didn't have to enter a login nor a password.
Diego.
Diego_V_Intel
Hello BenKissBox,
telnetd -l /bin/sh
Diego.
BBOUC2
New Contributor II
Hello Diego,
thank you for your investigation and your answer. To answer your different questions:
- I made the test on a Gen 1, not a Gen 2 (maybe it explains the difference, but I am convinced it's not the case)
- I just run a basic sketch with the following commands on the setup() function
system("ifconfig eth0 inet 192.168.0.150 netmask 255.255.255.0 up");
system ("telnetd");
in order to have a static IP address and the telnet daemon running
- I connect using the Mac OS Telnet client program. The problem occurs when I enter the command "open 192.168.0.50", I get the screenshot I reported just over there (asking me for a password)
Benoit
FTinetti
Honored Contributor I
Hi Benoit,
I think the problem is in the commands you are using:
system ("telnetd");
More specifically, I'm using
system ("telnetd -l /bin/sh");
I'm also using a little bit different command to "start" eth0, but it should not be a problem because you reported the ssh is working.
HTH,
Fernando.
Diego_V_Intel
Hello BenKissBox,
You mentioned that the issue only happens when booting the Galileo from the SD card Yocto image. What image are you using? I tested the Telnet connection using the following image: http://downloadmirror.intel.com/24355/eng/SDCard.1.0.4.tar.bz2 http://downloadmirror.intel.com/24355/eng/SDCard.1.0.4.tar.bz2. Please try with that image to see if you get different results.
And as FGT suggested, use the following lines in your Arduino sketch:
system("telnetd -l /bin/sh");
system("ifconfig eth0 169.254.1.1 netmask 255.255.0.0 up");
And add the following lines to check the eth0 interface settings in the Serial Monitor:
delay(3000);
system("ifconfig eth0 > /dev/ttyGS0");
Diego.
Community Manager
I don't have the SD Card image installed right now. But in most linux OS's there is a default setting to deny telnet access for root. This is because, as you know telnet traffic is transmitted in clear text . Since the root user is obviously a privileged account you would not use telnet for that user.
Look for a file in /etc called login, see if root is denied.
As an example on the iot dev kit the file is /etc/login.access
Cheers,
-Joe
FTinetti
Cheers,
-Joe
Hmmm... then we are using different yocto images... at the very least: I'm able to use telnet as described above (and which Diego has verified too).
Take into account that, as pointed out in another thread ( ):
There is a yocto intended to be used with XDK: "You can boot your Intel® Galileo board using a micro SD card that contains the latest Intel® IoT Developer Kit version of the Yocto* built, Linux image." (https://software.intel.com/en-us/programming-blank-sd-card-with-yocto-linux-image-windows Making a bootable micro SD Card with Windows* | Intel® Developer Zone) and there is an image not related to XDK, just intemded to be used for (Arduino) sketch persistency (maybe among other tasks I do not know about), so it is not necessary to have anything related to SDK-IoT Dev. Kit, etc., and which is the one I'm using and Diego suggested and included the link to.
About security... well... that's "beyond the scope" any analysis I could make right now...
HTH,
Fernando.
Community Manager
Well it was just a guess I am not using the SDCard.1.0.4.tar.gz right now. I am using the file iot-devkit-latest-mmcblkp0.direct which has those config options.
Cheers,
-Joe
BBOUC2
New Contributor II
Hello all,
thank you to Diego and FGT, your proposal were the right one.
If I use system("telnet -l /bin/sh"), I am able to log from a Telnet client without any problem (the Galileo does not ask anymore for login and password)
Benoit
