Community
cancel
Showing results for
Search instead for
Did you mean:
FLudw
Patch Edison Sound driver without flashing Complete Kernel
I would like to test a small modification in one of the I2S audio drivers without doing the whole development cycle and reflashing. I am not familiar with Linux Kernel development.
I have read http://www.intel.com/content/www/us/en/support/boards-and-kits/000005616.html Board Support Package (BSP) User Guide for Boards and Kits and http://shawnhymel.com/724/creating-a-custom-linux-kernel-for-the-edison-yocto-2-1/ Creating a Custom Linux Kernel for the Edison (release 2.1) | Shawn Hymel but both is a long way for a small change in only one driver.
Also I would like to keep my user data and installations. I tried the --keep-data option but the flashAll.sh from the build does not contain this option.
Thanks for all help.
Carlos_M_Intel
Hi freedy,
What kind of modification do you want to do? You can find the source files while building the image but you don't have access to those files while interacting with the board through the Terminal Console so you may need to build the image
Which is the driver you want to edit?
The available options for the flashall.sh script are:
-h,--help display this help and exit.
-v verbose output
--recovery recover the board to DFU mode using a dedicated tool,
available only on linux and window hosts.
Charlie
Carlos_M_Intel
Hi freedy,
I would like to know if you have been able to work on this.
Have you tried to build a new image with the changes you wanted?
Charlie
FLudw
I am able to build the kernel, but flashing the board would mean loosing all my installations, configurations I did. I can redo that, but that means long turn around times.
What I want to do is: I would like to connect a ICS43432 I2S Digital Microphone. For now I would just do modifications in the merr_dpcm_dummy.c file. First try would be to change LE to BE.
There should not be many changes to the dummy driver.
Carlos_M_Intel
Hi freedy,
Have you tried to do the changes and compile the driver on the image? If this is not working for you, I suggest you the following:
1. Create a backup of your image
2. Build a new image with the changes you need on the source files of the driver
3. Flash your custom image in the board
4. Restore the backup you have saved.
Charlie
FLudw
edit: the backup did work, so thanks for this, now I will go on trying to deploy single linux modules.
The problem below was due to having unknown partitions on the sdcard.
tried to do a backup, but I get
/media/sdcard# dd if=/dev//mmcblk0 of=backup20160218 bs=1M dd: writing 'backup20160218': No space left on device
14+0 records in
12+1 records out
when I try to fdisk:
fdisk /media/sdcard/
'/media/sdcard/' is opened for read only
Carlos_M_Intel
Hi freedy,
I'm glad to know that the backup worked for you.
Charlie
Matthias_H_Intel
not necessarily need to reflash everything. I sometimes just build a kernel package and opkg install it in the live system. Just make sure to update everything (especially also the modules). Don't forget the "modprobe -a" to regenerate the modules database. If everything went fine you should be on your new kernel after a reboot. Note: no guarantee that you won't break your installation using this approach. If you did then you'd have to reflash.
Carlos_M_Intel
Hi freedy,
I would like to know if you have tried with one of the alternatives we have suggested. Let us know if you have been able to work on this.
Charlie
