Community
cancel
Showing results for
Search instead for
Did you mean:
AJurk2
Photoresistor, Galileo Gen 1, Python pyGalileo library - little confustion
I have Galielo Gen1 and Debian Linux on SD Card working good. I use pyGalileo library to manage pins from Python scripts.
I can do LED Blinking as in youtube film: https://www.youtube.com/watch?v=_xaCrHob--U&list=UUyjJWfgBdAb50_JOqQ3Utdg LED blinking - YouTube.
Everything is also on Superteacher's Blog: http://www.superbelfrzy.edu.pl/linux-i-wioo/galileo-dalsze-postepy-w-pracy/ http://www.superbelfrzy.edu.pl/linux-i-wioo/galileo-dalsze-postepy-w-pracy/ (in polish language only, but code is in python ;-)
OK - that works well, so I try today to connect photoresistor to Analog A0 pin and try top read. The film is showing voltage : https://www.youtube.com/watch?v=5ws2DdMLtOk&feature=youtu.be VID 20150401 115913 - YouTube
The python code is:
while True:
foto_value = analogRead("A0")
print "Value is: "+ str(foto_value)
delay(5000)
The output is:
Value is: 2
Value is: 3
Value is: 2
Value is: 3
Value is: 3
Value is: 3
Value is: 3
Value is: 3
It looks like something is not working like should be. But even investigating pyGalileo source code does not gave me ani hint, why... Maybe someone will help?
Tags (1)
RBrad2
Valued Contributor I
Hi Abix
It is a bit difficult to figure out you problem without the rest of the code and a sketch or picture of your setup.
Are you using a voltage divider circuit with you LDR? From the video you posted it looks like you are just reading across the LDR. You need to connect the LDR from +5V to a resistor (about 10K works well) and then ground the other side of the resistor. You then take your readings from the junction of the LDR and resistor. see http://www.instructables.com/id/How-to-Use-a-Light-Dependent-Resistor-LDR/ How to Use a Light Dependent Resistor (LDR) for an example.
Did you try the example in PyGalileo?
rgb
AJurk2
Works like a charm ;-)
root@coderdojo-galileo:~/python_scripts# python fotorezystor_test.py
test pin on
test pin off
Value is: 862
Value is: 862
Value is: 861
Value is: 862
Value is: 864
Value is: 862
Value is: 828
Value is: 1990
Value is: 1978
Value is: 1972
Value is: 1968
Value is: 1966
Value is: 825
Value is: 837
Value is: 609
Value is: 637
Value is: 858
Value is: 829
Value is: 207
Value is: 181
Value is: 862
I have made 2 mistakes I think:
1) I've put "A0" in python code - should be "A5" - I look from secod side ;-)
2) Ground wire was connected to the opposite side of Galileo pins - I found strange behavior with LED blinks - if I connect pin4 and ground in the same series of pin, the light is bright, but when GND is from series of pins where 3,5 V and 5V is, the led blinks very little....
Nevertheless this problem is SOLVED ;-) rgba - thanks for any hints.
