I am trying to get edison to play a song on startup. I have the bluetooth device paired and edison is getting connected to the bluetooth speaker at startup. But I am not able to play a song on the speaker at start up though it works fine from a terminal.
This is the service I am using(songtest.service)
[Unit]
Description=song test
Wants=network-online.target sound.target bluetooth.target bluetooth.service pulseaudio.service obex.service bluetoothconnecttest.service
After=sound.target console-shell.service console-getty.service media-sdcard.mount bluetooth.target bluetooth.service pulseaudio.service obex.service bluetoothconnecttest.service
[Service]
Type=oneshot
ExecStart=/home/root/MPlayer-1.1.1/mplayer /home/root/done.mp3
[Install]
WantedBy=multi-user.target
bluetoothconnecttest.service is the service used to connect to the bluetooth speaker. When I check the output of ps, I can see that the process has definitely started:
1325 root 29288 S /home/root/MPlayer-1.1.1/mplayer /home/root/done.mp3
The line '/home/root/MPlayer-1.1.1/mplayer /home/root/done.mp3' works fine from the terminal and it plays the song on the bluetooth speaker.
Any help is appreciated.
Thanks!
I also tried to start with sh instead
ExecStart=/bin/sh -c "/home/root/MPlayer-1.1.1/mplayer /home/root/done.mp3"
Hi c2,
Thanks for your interest in the Intel® Edison™ Platform.
Yes indeed, it is strange that it runs on your Linux console, but not on the system service. From this behavior, I can conclude that there must be something wrong with your service configuration. I would encourage to check your [Service] section and add the line WorkingDirectory, also I would try to change the Type line. By the way I think that this document might be handy https://www.freedesktop.org/software/systemd/man/systemd.service.html# Options https://www.freedesktop.org/software/systemd/man/systemd.service.html# Options .
Finally, I would check the shebang on your service file, if you don't know what a shebang is, please see the image below in order to understand what I'm trying to explain (Look at the highlighted line).
Have a great weekend!
-Jose P.
I tried both. But there is no change. Here is the service now:
# !/bin/sh
[Unit]
Wants=network-online.target sound.target bluetooth.target bluetooth.service pulseaudio.service obex.service bluetoothconnecttest.service dbus.service
After=sound.target console-shell.service console-getty.service media-sdcard.mount bluetooth.target bluetooth.service pulseaudio.service obex.service dbus.service bluetoothconnecttest.service
[Service]
WorkingDirectory=/home/root/MPlayer-1.1.1/
[Install]
Hi c2,
I'm sorry to hear that my suggestion didn't work. I would like to perform a little experiment instead of using the ExecStart=/home/root/MPlayer-1.1.1/mplayer /home/root/done.mp3, I would like for you to use the Blink example . Please don't modify anything on the [Unit] and [Install] section, so your system service file should look like this:
[Unit]
[Service]
ExecStart=/usr/bin/node /home/root/blink.js
[Install]
We will be waiting for your results, have a nice day!
-Jose P.
Hello
I am using the sparkfun board for edison and I could not find the corresponding GPIO pin connected to led. I checked http://download.intel.com/support/edison/sb/edisonarduino_hg_331191007.pdf http://download.intel.com/support/edison/sb/edisonarduino_hg_331191007.pdf and http://mu.elecfans.net/201611/Intel-04-edisonbreakout_hg_331190006.pdf http://mu.elecfans.net/201611/Intel-04-edisonbreakout_hg_331190006.pdf . But I am not sure. I tried to run it without service first and no led was blinking. I tried with pin 13 acc. to the link .
But I have another service that works ok. Its bluetoothconnecttest.service which runs a script to connect to bluetooth speaker on startup.
bluetoothconnecttest.service:
[Unit]
Description=bluetoooth connect to speaker service
After=bluetooth.target hostapd.service pulseaudio.service
Wants=bluetooth.target pulseaudio.service
[Service]
Type=oneshot
ExecStart=/home/root/register_bt_speaker.sh
[Install]
register_bt_speaker.sh:
# !/bin/bash
mac_addr=58:56:12:30:09:9D
sink_addr=$(echo "$mac_addr" | tr ':' '_')
echo "Connecting device $mac_addr and sink $sink_addr"
rfkill unblock bluetooth
sleep 2
# bluetoothctl <<< "unblock $mac_addr"
while bluetoothctl <<< "info $mac_addr" | grep "Connected: no"; do
bluetoothctl <<< "connect $mac_addr"
echo "connecting $mac_addr ...."
sleep 10
done
sleep 5
pactl set-default-sink bluez_sink.58_56_12_30_09_9D
Thanks!
Hi c2,
I'm glad to hear that you were able to solve your issue by own! And thanks for sharing your solution in such a detailed manner, it will be useful for other members of the community having similar issues.
Have a great day!
-Jose P.
My issue is not solved!!!
My problem is that music is not played on the Bluetooth speaker. I can connect to Bluetooth speaker at start up.. I execute the second service (song test) after Bluetooth connect. I can even see the process /home/root/MPlayer-1.1.1/mplayer /home/root/done.mp3 start but its not being played!!!
Thanks!
Hi c2,
I apologize when I read "But I have another service that works ok" I thought that you were able to solved your issue.
Would you be so kind to explain me the Wants and After of your [Unit], I'm referring to these ones:
We will be waiting for your reply, have a nice day!
-Jose P.
Its dependencies for this service. More details are here: https://www.freedesktop.org/software/systemd/man/systemd.unit.html https://www.freedesktop.org/software/systemd/man/systemd.unit.html
I was not sure which all to add. So I added most services related to Bluetooth or sound. bluetoothconnecttest.service is the service connecting the speaker to edison. That is required. Without it, this service might start before the speaker is connected. I think that I might not have added all the services needed to play music on bluetooth speaker?
Hi c2,
Unfortunately, I don't have a speaker, so I can't replicate your issue. At the moment the best advice that I can give you is to try to use another ExecStart file with the song service, this in order to see if the root of the error is in the Wants and After that you define in your [Unit] section.
-Jose P.
Hi c2,
Were you able to solve your issue? Has my advice been helpful? Please let me know to see if there is anything else that we can do for you.
-Jose P.
No. Its not resolved. If I use another Execstart it works. Even this Execstart works and I can see the process running also! But music is not playing!
Hi c2,
I'm sorry to hear that it is still not working. Unfortunately, like I mention we don't have the necessary hardware in order to replicate your issue. If another Execstart worked then I can conclude that you might no have added all the services needed to play music, so you might want to look into that. We would like to apologize for not being able to help you any further, maybe other members of the community might share their feedback with you.
-Jose P.
