Community
cancel
Showing results for
Search instead for
Did you mean:
JJord1
Port 5683
I have a Galileo Gen 2 board. I want to write an aplication that communicates using the COAP protocol in C. I am seeing that port udp 5683, supposedly the well known port for this protocol, is taken by some process I cannot identify. I have succesfully communicated using other ports. How can I set the port free? How can I know what is running there? Can it be disabled?
thanks,
Jordi
FTinetti
Honored Contributor I
Hi Jordi,
How do you know the port "is taken"? What are you using to know it?
What do you mean by "disabled" (a port cannot be "disabled")?
Fernando.
JJord1
When I run "netstat -a" on the command line I see this:
Proto Recv-Q Send-Q Local Address Foreign Address State
udp 704 0 0.0.0.0:5683 0.0.0.0:*
When I say disable, I mean the process that is listening on the port, not the actual port. What I want to find is a way to identify who is listening on that port, so I can get my aplication there.
Jordi
FTinetti
Jordi
I see... did you try any other netstat option (e.g. -p)? You can see the complete set of options and information netstat is able to provide by using
man netstat
(even in a web browser).
HTH,
Fernando.
JJord1
There is no man installed .
That worked. Thanks
FTinetti
Yes, that's why I wrote
"(even in a web browser)."
That worked. Thanks
You're welcome,
Fernando.
