Community
cancel
Showing results for
Search instead for
Did you mean:
MClif
Power Supply for Intel Edison Arduino Board
Jump to solution
Looking at this page:
https://software.intel.com/en-us/get-started-edison-linux https://software.intel.com/en-us/get-started-edison-linux
These are the requirements:
7-15V DC
At least 1500mA
The center/inner pin should be the positive pole of the power supply
But it doesn't clarify the size of the 5.5mm barrel connector (see below).
And this is the suggested part number: EMSA120150
According to DigiKey it is a non-stock item BUT has a direct substitute of SMI18-12-V-P5:
http://www.digikey.com/product-detail/en/EMSA120150K-P5P-SZ/T1109-P5P-ND/2352102 http://www.digikey.com/product-detail/en/EMSA120150K-P5P-SZ/T1109-P5P-ND/2352102
Looking at the datasheet for the smi18:
http://www.cui.com/product/resource/smi18.pdf http://www.cui.com/product/resource/smi18.pdf
Scrolling down to page 4, there are TWO 5.5mm choices.
5 & 6 both have an outside diameter of 5.5mm. 5's inside diameter is 2.1mm and 6's is 2.5
Question: Does the Edison Arduino board require the the 2.1mm which is size 5 and therefore matches the SMI18-12-V-P5.
Bill
Diego_V_Intel
Hello Bill.,
If you check the datasheet of the recommended power supply, you will find that it has a 2.1mm I.D. Also, I realized that the item is in stock so I recommend you to check again. Anyhow, if you want to get another power supply, the I.D must be 2.1mm.
Diego.
Diego_V_Intel
Hello Bill.,
Diego.
