Community
cancel
Showing results for
Search instead for
Did you mean:
bbogu1
Power consumption details or calculator
Jump to solution
I was looking through docs of D2000 microcontroller for some information about power consumption and was able to sum it up as following:
There was information about currents for some peripherals but I couldn't find any information about voltages that it was measured for to calculate power consumption. Is there any more detailed information on this matter ? It would me ideal to have a power calculator - is there such thing ?
Bartosz
Juan_M_Intel
Hi Bartosz,
All of the documentation available regarding the Quark Microcontroller D2000 is posted at http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/d2000/documentation.html this site, but currently there isn't any power calculator for the microcontroller.
JPMontero_Intel
Juan_M_Intel
Hi Bartosz,
JPMontero_Intel
MPERE18
I am using POWER example provided in ISSM on Intel Mint Field Fab C Development kit Quark D2000. I succesfully put the micro on sleep and wake up from RTC interrupt, but I cannot wakeup micro from deepsleep. Analog input A5 pin is 3.3V by default, but if I connect A5 to GND before running the example UART does not work.
On the other hand I am checking current consumption in sleep and deep_sleep mode on Intel Mint Field Fab C Development kit and the less current consumption I can get is 11mA, how can I achieve the uA that datasheet says?
Thanks in advance,
Regards.
Juan_M_Intel
Hi marperez,
We have noticed that you have created a /thread/102438 new thread regarding this same situation. We will work on your question and will provide suggestions, but in the thread to avoid duplication.
JPMontero_Intel
