Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Power for Development Board
thought I'd save other newbies this problem.
Plugged in a wall wart, 12 volts, center pos. No joy. no lights. Measured the power on the connector and it was ~15v.
Tried a bench power supply at 12 v and the lights came up and the Joule booted.
BEWARE THE WALL WART WITH ITS LOOSE SPEC!
Someone asked about the draw and my board at idle seems to be consuming 0.2 amps
Community Manager
Hi electricphred,
Thank you very much for your inputs on this issue. I'm sure it will help some other users.
-Pablo
