Community
cancel
Showing results for
Search instead for
Did you mean:
RKuma42
Powering OFF Flashes The Previous Burnt Program
Jump to solution
HI,
The thing is that when I am uploading the code that time my program runs well.
But when I powered OFF Intel baord, then Powering On Intel board my Previous Burnt Code get flashed off can u tell me some suggestion ?
So that I can make my Intel Edison board must be standalone so that whenever I power on the Intel Edison It should ready to run the previous Burnt program??
These are Methods which are we executed On Intel Edison board.
"I need to execute a binary while the Intel edison board is booting up.
To test I have created a script under /etc/init.d which will create file under /tmp, but it is not creating. Can you help me why it is not executing the script placed under /etc/init.d during boot time.
script contains only the following command
touch /tmp/hi
Below is the code in the script file
# !/bin/sh
exec /sketch/sketch.elf /dev/ttyGS0 /dev/ttyGS0 "
If u give some idea How to do that it will be very helpful to us?
thanks
Community Manager
Hello rahul147258,
This is a known issue that has been present for a while. There is a workaround to fix it created by a user of the community, you can find it in https://communities.intel.com/thread/77945 https://communities.intel.com/thread/77945.
You could also try to use an image that did not have this issue. The last image that didn't have the issue present was the release 2.1 (version 146) which can be found in https://downloadmirror.intel.com/24910/eng/edison-image-ww18-15.zip.
I'd suggest you to either try to apply the workaround to the latest image or to use the image 146 for your project. We apologize for the issues that this might cause.
Let me know if this information helps you.
-Peter.
Community Manager
Hello rahul147258,
-Peter.
