Community
cancel
Showing results for
Search instead for
Did you mean:
NFiam
Presale question: Works also without connection to HDMI?
can anyone help, if the sticks works also if the HDMI is not connected?
I have a small application that I want to run on it (connected with power by USB and Wifi for internet).
I hope someone can give me a hint :-)
Thanks in forward
Nino
Hellen_D_Intel
Hi Nino_Paraguay,
If you would like to use the unit headless (connected to the power but not to the HDMI), and remotely access it, yes that should work; if you would like to output video via USB chances are that it is not going to work.
Hellen.
