Intel® Makers
9880 Discussions
Problem Intel Galileo Gen 2 with Relay Module
kiman
Hi Guys ,
i have a problem with my galileo . i make a project who use Relay module to power AC component like AC Light , Thermoelectric and Water Pump (every component have a power supply ) .
but i got problem when i give power on my galileo and galileo turn on , relay module did not run . i use other component like DHT22 sensor , LDR , moisture and LCD it can run correctly when the galileo on . just relay module who not run.
i have to reupload the program to make it run correctly . i try with other relay module and still got some problem .
anyone have some problem and have fix it ?
please help me ....
sorry for my english
thanks ,
FTinetti
Honored Contributor I
Just curious: how are you using the DHT22? Would you please send some code example?
TIA,
Fernando.
kiman
i follow
it working correctly . if you use DHT11 you need resistor 10k and also Diode . If you use DHT22 you need 74hc125 and resistor 10k .
for code i use code from example in library . i cant share it over here because too long ( over 400++ lines)
FTinetti
Thank you very much,
Fernando.
Community Manager
Hello Fladevix,
How are you connecting your board to the relay module? Could you please send us a schematic of how you would connect the two? And if possible share with us a picture of the physical connection of both boards.
You mention that the relay module is powered separately from the Galileo, so, I suspect that maybe the circuit might not be properly connected.
-Peter.
Community Manager
Hi Fladevix,
Is there any update about this? Do you still need help?
-Peter.
