Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Problem booting Galileo Gen2 with no SD card
I am using the USB connection (not mini-USB) with no SD card installed on a Galileo Gen 2. I can connect with Putty (using Com10) but only get to the grub> prompt. If I reboot grub I see the options as shown in the picture below, but neither works.
The mini-USB port appears to be completely dead. My PC will not even recognize this as an available port/device.
Additionally, if I run the Galileo firmware updater it sees that Com10 is the configured port but the updater will not detect the current board firmware and will not install 1.0.4. See second picture below.
What am I missing?
Thanks!
Highlighted
Hi IOT-fan,
Have you been able to use your Galileo before? Or is this the first time you use it?
When connecting the Mini-USB do you see some changes in the Device Manager? Could you please share an image of your Device Manager?
PabloM_Intel
Highlighted
Hi Pablo,
I have been able to boot from the SD card (Yocto image installed) and use the Intel XDX IOT Edition to connect to the Galileo and build/run programs.
One data point I did not mention before is that I received the Galileo in a boot camp course and so I am not sure if anything has been changed on the device's firmware. I suspect this is where the problem lies.
When connecting with the mini-USB, there are no changes in Device Manager (a picture would not be very useful ). It is as if that serial port is completely dead. If I use the other cable (TTL header) it is detected and on my computer assigned to COM10.
Highlighted
Hi IOT-fan,
Have you tried running the UEFI internal shell recovery method? You can check an explanation under section 10 of the next document http://www.intel.com/support/processors/quark/sb/CS-035211.htm http://www.intel.com/support/processors/quark/sb/CS-035211.htm. The process uses two files created in section 8, so you'll need to keep an eye on that.
If you have access to a Dediprog, you can also try to recover your Galileo board that way (this is the easiest way, but not everyone has access to a Dediprog), you can check the instructions under section 11 of the document above.
Some time ago, another user developed a method that he called "Galiprog", in which a second Galileo device acts as a programmer. If you have a second Galileo board you can follow the instructions from here: https://github.com/xbolshe/galiprog https://github.com/xbolshe/galiprog.
PabloM_Intel
Highlighted
Hi IOT-Fan
Is your issue resolved ?
If yes, could you please share what method you used to solve your problem to boot the Galileo Gen2 without SD card.
Highlighted
Hi Abhatikar,
Are you having the same issue as IOT-fan? Have you tried with the methods above? What have been your results?
Pablo
Highlighted
Honored Contributor I
Would you describe the problem you have? Meaningful screenshots help a lot for describing problems.
Fernando.
