my Edison is unable to connect to the WPA2 enterprise network. is it got any setting or step need to done before connect? like, insert the WPA cert into intel Edison? if yes then what is the way?
How are you attempting to connect to this network? There's some additional configuration required. You need to have the certificates inside the network configuration so they're recognized and you'll be able to connect. The certificates should be placed in the /etc/wpa_supplicant/wpa_supplicant.conf.
This is an example of how the wpa_supplicant.conf file should look like
network={
ssid="WPI-Wireless"
key_mgmt=WPA-EAP
proto=WPA2
pairwise=CCMP
group=CCMP
eap=TLS
identity="[YOUR_WPI_EMAIL]@wpi.edu"
ca_cert="/home/pi/certs/CA-[A_BUNCH_OF_NUMBERS].pem"
client_cert="/home/pi/certs/certificate.pem"
private_key="/home/pi/certs/certificate.p12"
private_key_passwd="[YOUR_WPI_EMAIL_PASSWORD]"
priority=1
You can see more information here /message/343704# 343704 https://communities.intel.com/message/343704# 343704
-Sergio
network={
ssid="WPI-Wireless"
key_mgmt=WPA-EAP
proto=WPA2
pairwise=CCMP
group=CCMP
eap=TLS
priority=1
-Sergio
I tried the method above but it still cant, it shows
Attempting to enable network access, please check 'wpa_cli status' after a minute to confirm.
not connected.something went wrong
warning: SSH is not yet enabled on the wireless interface. To enable SSH access to this device via wireless run configure_edison --password first.
Could you provide the full output of wpa_cli status? Have you already configured SSH as pointed in the warning massage? Enable SSH and let us know your results.
We'll be waiting for your response.
-Sergio
thanks Sergio,
after I delete all the data in /etc/wpa_supplicant/wpa_supplicant.conf and retype the code that you give me , its work!!!
