Community
cancel
Showing results for
Search instead for
Did you mean:
RArgh
Problem for connected the adress ip of the intel galileo gen 2 to sofware Intel System Studio Iot (C/C++).
My name is Redda and i search at solve my problem wich lasts now 5 days.
My problem is that i do not arrive at connected the adress ip of my intel galileo gen 2 (via ethernet)
to sofware Intel System Studio Iot(C/C++), i have all try but i do not find all alone.
However i have enter all the information correctly but the sofware tells me
" Could not connect to target 192.168.x.xx
Please check your proxy settings and ensure that your credentials
are correct.
If you are unsere you can clear your credentials in the context
menu of the connection."
please help my at solve this problem.
Community Manager
Hi Redda,
Thank you for reaching out. We understand your frustration and we would like to help you.
Could you please let us know what you have tried so far?
Also, did you make sure to add a password to your Intel Galileo board?
-Pablo
RArgh
Hi my intel galileo gen 2 has not of password is it obligatory and if yes how to do it.
Community Manager
Hi Redda,
I apologize, I forgot to first ask you if you were using an SD card image or just using the Flash memory of the Galileo board. Could you please let us know which one you're using? For the most part of the Galileo features, having an SD image is necessary, check these steps in case you haven't done this before https://software.intel.com/en-us/get-started-galileo-windows-step1 https://software.intel.com/en-us/get-started-galileo-windows-step1.
-Pablo
Community Manager
Hi Redda,
Do you have updates on this case?
Pablo
RArgh
I Still have not found how to do for connected the Intel Galileo gen2 to sofware Intel System studio.
I bought the Intel Centrino for to avoid of to stay glue to office.
Community Manager
Hi Redda,
It will be easier to help you know that you bought a WiFi antenna. As I asked you some time ago, I would like to know if you're using an SD card image or if you're currently working with the flash memory of the board. Which one are you using?
-Pablo
RArgh
Hi
I use a SD card image, the image Yocto.
Community Manager
Hi Redda,
I would suggest you to try with an older version of the software, I would like to confirm if the issue is happening with every version of ISS or only with the latest(s) version. If you're unsure on how to proceed with this check this link https://software.intel.com/en-us/articles/older-version-product https://software.intel.com/en-us/articles/older-version-product.
I've been checking some other threads and found some other users having issues when creating Galileo projects (the option is no longer available), like in this one /thread/108717 https://communities.intel.com/thread/108717. That's what I would like you to test with older versions.
-Pablo
AN__D
Hy Redda,
I use the "Bonjour Browser" app for my macmini to see the Intel Galileo IP. You can try to use this app if you use Mac too.
RArgh
thank you but i use windows.
