Community
cancel
Showing results for
Search instead for
Did you mean:
ASund3
Problem installing Ubilinux in Intel edison
Jump to solution
I followed the https://learn.sparkfun.com/tutorials/loading-debian-ubilinux-on-the-edison Loading Debian (Ubilinux) on the Edison - learn.sparkfun.com tutorial and I went through the flashall.sh script. After it finished I noticed the Edison rebooted a couple of times, and after about 10 minutes it prompted that the flash is success. But when I try to boot using putty from windows and "sudo /dev/ttyACM0 115200" cmd from linux i get a blank screen and i dont see any response when I press enter repeatedly. Any help would be much appreciated. Thanks
Here are the last lines of the boot sequence:
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
Flashing IFWI
# # ] finished!
# # ] finished!
Flashing U-Boot
# # ] finished!
Flashing U-Boot Environment
# # ] finished!
Flashing U-Boot Environment Backup
# # ] finished!
Rebooting to apply partition changes
Flashing boot partition (kernel)
# # ] finished!
Flashing rootfs, (it can take up to 10 minutes... Please be patient)
# # ] finished!
Rebooting
U-boot & Kernel System Flash Success...
Your board needs to reboot to complete the flashing procedure, please do not unplug it for 2 minutes.
Carlos_M_Intel
Hi Ash91,
I saw on the tutorial you posted, the following Warning:
WARNING: Once the command prompt window closes, you will need to wait at least 2 minutes for the installation to complete. The Edison should reset a couple of times to finalize its installation. Do not unplug the Edison! It's probably a good idea to walk away for those 2 minutes.
Have you tried with a different USB port (Not sure if you are using the same PC) or different cables?
I suggest you to re-do the Flashing Process and to try with the Yocto image
If you want to continue with Ubilinux, I suggest you to contact http://www.emutexlabs.com/forum/index EmutexLabs for more appropriate assistance regarding this image.
Kind regards,
Charlie
Carlos_M_Intel
Hi Ash91,
Kind regards,
Charlie
ASund3
Hi Charlie,
Thanks for the reply. The issue was with the USB cable that i used, with another USB cable it worked without any probs.
