I'm currently trying to install mplayer with pulse audio in order to play some music via bluetooth headphones that I have already successfully connected with the edison.
I was initially following the correct answer /message/308907# 308907 here and installed mplayer, but couldn't play audio because it doesn't know the pulse audio output.
I then tried the correct answer /thread/75748 here but I cannot install some of the libraries that are mentioned there.
Going through /message/310610# 310610 the correct answer, here are the errors i get:
root@edison:~# opkg install libavahi-client-dev
Unknown package 'libavahi-client-dev'.
Collected errors:
* opkg_install_cmd: Cannot install package libavahi-client-dev.
root@edison:~# opkg install pulseaudio-dev --force-reinstall --force-overwrite
Downloading http://repo.opkg.net/edison/repo/core2-32/pulseaudio-dev_6.0-r0_core2-32.ipk http://repo.opkg.net/edison/repo/core2-32/pulseaudio-dev_6.0-r0_core2-32.ipk.
Multiple packages (pulseaudio-dev and pulseaudio-dev) providing same name marked HOLD or PREFER. Using latest.
Installing pulseaudio-dev (6.0-r0) on root.
pulseaudio-dev: unsatisfied recommendation for libavahi-client-dev
alsa-lib-dev: unsatisfied recommendation for alsa-conf-base-dev
alsa-lib-dev: unsatisfied recommendation for libasound-dev
alsa-lib-dev: unsatisfied recommendation for alsa-conf-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-lib-protocol-simple-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-stream-restore-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-null-sink-dev
libx11-dev: unsatisfied recommendation for libx11-xcb-dev
libxcb-dev: unsatisfied recommendation for libxcb-shape-dev
libxcb-dev: unsatisfied recommendation for libxcb-dpms-dev
libxcb-dev: unsatisfied recommendation for libxcb-render-dev
libxcb-dev: unsatisfied recommendation for libxcb-shm-dev
libxcb-dev: unsatisfied recommendation for libxcb-dri3-dev
libxcb-dev: unsatisfied recommendation for libxcb-damage-dev
libxcb-dev: unsatisfied recommendation for libxcb-glx-dev
libxcb-dev: unsatisfied recommendation for libxcb-composite-dev
libxcb-dev: unsatisfied recommendation for libxcb-res-dev
libxcb-dev: unsatisfied recommendation for libxcb-xvmc-dev
libxcb-dev: unsatisfied recommendation for libxcb-xkb-dev
libxcb-dev: unsatisfied recommendation for libxcb-sync-dev
libxcb-dev: unsatisfied recommendation for libxcb-xevie-dev
libxcb-dev: unsatisfied recommendation for libxcb-dri2-dev
libxcb-dev: unsatisfied recommendation for libxcb-randr-dev
libxcb-dev: unsatisfied recommendation for libxcb-record-dev
libxcb-dev: unsatisfied recommendation for libxcb-xprint-dev
libxcb-dev: unsatisfied recommendation for libxcb-xv-dev
libxcb-dev: unsatisfied recommendation for libxcb-xtest-dev
libxcb-dev: unsatisfied recommendation for libxcb-screensaver-dev
libxcb-dev: unsatisfied recommendation for libxcb-present-dev
libxcb-dev: unsatisfied recommendation for libxcb-xf86dri-dev
libxcb-dev: unsatisfied recommendation for libxcb-xinerama-dev
libxcb-dev: unsatisfied recommendation for libxcb-xfixes-dev
pulseaudio-dev: unsatisfied recommendation for udev-dev
pulseaudio-dev: unsatisfied recommendation for libsystemd-dev
libsndfile-dev: unsatisfied recommendation for libasound-dev
libsndfile-dev: unsatisfied recommendation for sqlite3-dev
pulseaudio-dev: unsatisfied recommendation for shadow-sysroot-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-lib-oss-util-dev
consolekit-dev: unsatisfied recommendation for dbus-lib-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-native-protocol-unix-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-lib-avahi-wrap-dev
pulseaudio-dev: unsatisfied recommendation for libpulse-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-always-sink-dev
pulseaudio-dev: unsatisfied recommendation for libudev-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-lib-protocol-cli-dev
pulseaudio-dev: unsatisfied recommendation for libx11-xcb-dev
pulseaudio-dev: unsatisfied recommendation for libasound-dev
pulseaudio-dev: unsatisfied recommendation for libpulse-simple-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-loopback-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-augment-properties-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-lib-protocol-http-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-udev-detect-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-suspend-on-idle-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-bluez5-discover-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-rescue-streams-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-position-event-sounds-dev
e2fsprogs-dev: unsatisfied recommendation for libcomerr-dev
e2fsprogs-dev: unsatisfied recommendation for e2fsprogs-badblocks-dev
e2fsprogs-dev: unsatisfied recommendation for libe2p-dev
e2fsprogs-dev: unsatisfied recommendation for update-alternatives-opkg-dev
e2fsprogs-dev: unsatisfied recommendation for libext2fs-dev
e2fsprogs-dev: unsatisfied recommendation for libss-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-cli-protocol-unix-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-role-cork-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-detect-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-filter-heuristics-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-lib-cli-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-bluetooth-policy-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-bluez5-device-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-alsa-source-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-default-device-restore-dev
jack-dev: unsatisfied recommendation for libjack-dev
jack-dev: unsatisfied recommendation for libasound-dev
flac-dev: unsatisfied recommendation for libflac-dev
flac-dev: unsatisfied recommendation for libflac++-dev
lirc-dev: unsatisfied recommendation for libjack-dev
libportaudio-dev: unsatisfied recommendation for libasound-dev
libportaudio-dev: unsatisfied recommendation for libjack-dev
lirc-dev: unsatisfied recommendation for libsystemd-dev
lirc-dev: unsatisfied recommendation for libasound-dev
pulseaudio-dev: unsatisfied recommendation for libavahi-common-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-alsa-card-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-filter-apply-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-card-restore-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-lib-rtp-dev
pulseaudio-dev: unsatisfied recommendation for pulseaudio-module-intende...
What libraries were you not able to install?
If you are having problems with libavahi why don't you try to install the packages individually?
Try with opkg install libavahi-client3
To download packages individually run wget http://repo.opkg.net/edison/repo/core2-32/%3cpackage_name%3e.ipk http://repo.opkg.net/edison/repo/core2-32/.ipk. This will allow you to download packages from http://repo.opkg.net/edison/repo/core2-32/ Index of /edison/repo/core2-32 .
Some of the errors seem to be related to missing dependencies. Install all dependencies needed and let us know your results.
Sergio
So I have been looking into this a bit more, looks like the problem is an incorrect (?) dependency in the package jack-dev on the package jack.
(I am using the AlexT_Intel repo)
Installing jack-dev without dependencies seems to completely solve this (see also /message/301089# 301089 this thread):
opkg install libjack
opkg install --nodeps jack-dev
worked for me, I now have pulse installed and am currently recompiling mplayer, I will see if my bluetooth headphones work then...
I'm not sure if avahi is even needed for my usecase, I just ignored and installed without it...
Thanks for your help!
Cooper
Edit: everything works now, marking as correct.
Yes, that's exactly the case, jack package for whatever reason is generated with broken dependencies (even though on the recipe level everything looks ok). There were no reports for anyone having problems with this too much (at least not those that @-mentioned me, anyway ), so I've never bothered to investigate this further.
Thanks for sharing the workaround.
