Community
cancel
Showing results for
Search instead for
Did you mean:
JMona1
Problem switching Edison units in Eclipse
Jump to solution
I have been using an Edison/Breakout board with the Eclipse for some time over WiFi.
I want to run the same C code on a second Edison board over the same WiFi system (i.e. switch boards).
Since it has a different IP address I first used the menu Intel(R) IoT / Create a target connection. I add a new name and use the IP address of the new unit. When I hit "Run" button everything seems to go fine in accessing the Edison. However about 91% of the way I get:-
"error while loading shared libraries: libmraa.so.1: cannot open shared object file: No such file or directory
logout"
I do not get this when I go back to the first unit.
What is the problem and how do I correct it. I'm a complete newbie so please help with some detail
Tags (1)
Community Manager
Hi Monahanz,
Thanks for contacting us!
We would like to suggest you to update MRAA and UPM libraries, please take a look at this link: https://software.intel.com/en-us/node/623543 Updating the MRAA I/O and UPM, there you can find instructions on how to update them and then try running your code again.
If you continue getting that error message, please take a look at this link: https://github.com/intel-iot-devkit/mraa/issues/502 https://github.com/intel-iot-devkit/mraa/issues/502, there is a discussion about this error message, as a summary the error message is about a missing libmraa.so.1 file, you can solve this by creating a symbolic link with that name in /usr/lib pointing to libmraa.so.0. Please read that discussion for more details.
Hope this information helps.
-Yermi
Community Manager
Hi Monahanz,
-Yermi
