Intel® Makers
9881 Discussions
Problem when install MeshCenter's Agent to Intel Galileo Gen 2
JSh
Intel Galileo Gen 2
Firmware: 1.0.4
Linux: iot-devkit-1.5-i586-galileo (http://downloadmirror.intel.com/25028/eng/iot-devkit-1.5-i586-galileo.bz2 http://downloadmirror.intel.com/25028/eng/iot-devkit-1.5-i586-galileo.bz2)
root@galileo:~# cat /etc/version
201510010732
When I run command:
root@galileo:~# mkdir /usr/mesh
root@galileo:~# wget http://www.meshcentral.com/public/dh.ashx?mesh=69ED798675AA4E9C7CDE7EE01EC22ACCFB7FE989E58B3BEA04EEA... http://www.meshcentral.com/public/dh.ashx?mesh=69ED798675AA4E9C7CDE7EE01EC22ACCFB7FE989E58B3BEA04EEA... -O /usr/mesh/mesh_linux.msh
Connecting to http://www.meshcentral.com/ www.meshcentral.com (198.175.87.57:80)
mesh_linux.msh 100% |*******************************| 3838 0:00:00 ETA
root@galileo:~# wget http://www.meshcentral.com/public/dh.ashx?agent=15 http://www.meshcentral.com/public/dh.ashx?agent=15 -O /usr/mesh/mesh_linux
mesh_linux 100% |*******************************| 795k 0:00:00 ETA
root@galileo:~# chmod 755 /usr/mesh/mesh_linux
root@galileo:~# /usr/mesh/mesh_linux start
/usr/mesh/mesh_linux: can't load library 'libutil.so.0'
Is devkit's image wrong? or need additional packets?
Pablo_M_Intel
Hi Jek2k,
Did you already try adding the MeshCentral agent through the Arduino sketch? https://software.intel.com/en-us/blogs/2013/10/18/meshcentralcom-now-with-intel-galileo-support https://software.intel.com/en-us/blogs/2013/10/18/meshcentralcom-now-with-intel-galileo-support.
You can check the instructions in the link above. It's been tested using the SPI flash image, so I'm not sure if it's going to work with the SD card image but you can give it a try.
Here's another related video http://www.intel.com/content/www/us/en/embedded/products/galileo/galileo-09-meshcentral-video.html http://www.intel.com/content/www/us/en/embedded/products/galileo/galileo-09-meshcentral-video.html.
PabloM_Intel
Pablo_M_Intel
Hi Jek2k,
PabloM_Intel
JSh
Hi!
Thank for your answer.
After download and flash "https://downloadcenter.intel.com/ru/downloads/eula/24355/Intel-Arduino-IDE-1-6-0?httpDown=https://do... SDCard.1.0.4.tar.bz2" I was install MeshCentral's agent.
JSh
Do you plan to support Yocto or Debian?
Pablo_M_Intel
Hi Jek2k,
We only support the Yocto image. For other images I would suggest you to look at the developers sites for more information.
PabloM_Intel
