Community
cancel
Showing results for
Search instead for
Did you mean:
OAfol
Problem with Edison driver
Once I connect the Edison to my computer a pop up appears saying 'You need to format the disk in drive G before you can use it'. What can I do to fix this ?
Thanks in advance.
Community Manager
Hi Feyiafolabi,
Thank you for contacting us. This seems to be an issue with the drivers. Would you please let us know what guide have you followed to install the drivers needed to use the Edison? The guide you need to be following is this one: https://software.intel.com/en-us/get-started-edison-windows-32-step2 https://software.intel.com/en-us/get-started-edison-windows-32-step2 . After completing these steps please let us know if you're successful. If not, please attach pictures to see where the process fails.
It'd also be useful to know how you're connecting your Edison to the PC. Are you only connecting J16 or both J16 and J3?
We'll be waiting for your response.
-Sergio A
Community Manager
Hi Feyiafolabi,
Do you still need assistance with this case?
-Sergio A
