Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
Problem with Examples for Other Languages
I was not able to run any of the JavaScript or Python examples for other languages:
https://software.intel.com/en-us Home ' https://software.intel.com/en-us/intel-software-technical-documentation Documentation ' https://software.intel.com/en-us/next-steps-create-applications-with-devkit Next Steps: Create Applications with DevKit ' https://software.intel.com/en-us/node/519970 Analog I/O Basics ' https://software.intel.com/en-us/node/519980 Sample Code
Then by experimenting, I changed the line in the JavaScript example
var m = require("mraajs");
to
var m = require("mraa");
and it works OK.
Same thing in the Python example. I changed the line:
import pymraa
to
import mraa
and it runs OK.
Are these references to mraajs and pymraa just an error in documentation, or am I missing something?
I am running these directly on the Edison from its Linux command line.
Highlighted
Re: Problem with Examples for Other Languages
Thanks Marvin. You are right, the documentation needs to be updated.
Raghu Kona
Highlighted
Thank you indeed. I've fixed the samples. Let us know if you find any other broken sample.
Sulamita Garcia
