Intel® Makers
9881 Discussions
Problem with Uploading Sketch via Arduino IDE
Community Manager
I was following the first few steps to "/thread/77945 Run Arduino sketch on boot Workaround", when I decided not to proceed. I had not done any flashing, but was just going through the motion to get familiar with the workaround procedure. But I did archive all the files that I needed, including the files in the /opt/edison folder.
I decided to restore my backup files, including "launcher.sh", "clloader", "sketch_reset", and "sketch_reset.sh" which I had archived to my Windows notebook using WinSCP. I uploaded these 4 files back to the /opt/edison folder. - Doh!
Now whenever I compile in the Arduino IDE, I get this output from the bottom half of the IDE window:
<<COMPILING SKETCH SUCCESSFUL>>
<<LINKING SKETCH SUCCESSFUL>>
Sketch uses 100,829 bytes (1%) of program storage space. Maximum is 10,000,000 bytes.
# !/bin/sh
starting download script
Args to shell: C:\Users\S7045719I\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\S70457~1\AppData\Local\Temp\buildb92e1b2eb45da914b588ae48cf361e8d.tmp/GraphicsTest.ino.elf COM43
# clupload script to invoke lsz
# Copyright (C) 2014 Intel Corporation
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 2.1 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
COM PORT 43
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Converted COM Port COM43 to tty port /dev/ttyS42
Sending Command String to move to download if not already in download mode
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
# path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
# COM ports are not always setup to be addressed via COM for redirect.
# /dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadEdison" > $tty_port_id
C:\Users\S7045719I\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 42: /dev/ttyS42: Permission denied
# Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
C:\Users\S7045719I\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 46: /dev/ttyS42: Permission denied
# Execute the target download command
# Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
C:\Users\S7045719I\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 51: /dev/ttyS42: Permission denied
Moving downloaded file to /sketch/sketch.elf on target
# mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name# */}"
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz.exe" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" <> $tty_port_id 1>&0
C:\Users\S7045719I\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 56: /dev/ttyS42: Permission denied
My Arduino ino script does not get uploaded to the Edison anymore. There is no response from the Edison via the IDE, although I can still Putty or WinSCP and access the folders within. It's like the files (launcher.sh, clloader, sketch_reset, and sketch_reset.sh) got corrupted? But it can't be, right? Do I need a chmod somewhere?
What could have happened? Is there anyway that I can recover without having to go through the hassle of re-configuring the Edison all over again?
Thanks in advance,
Gavin
Community Manager
Ok... found it. Here's a thread that answers my question -
Answer # 12 by JasonZ solved my problem.
Thanks for reading.
Gavin
Community Manager
Thanks for reading.
Gavin
