Intel® Makers
9874 Discussions
Problem with bios-paired bluetooth keyboard
JSams1
It seems to be a very flawed implementation. While it initially appears to work, when any device is paired with the bios, the unit will not boot until you wake up the keyboard and establish a connection. While this may be suitable for some cases where frequent interaction with the bios or bootloader are necessary, it is frustrating for a "normal" user, who only occasionally needs to interact with bios/bootloader.
I would suggest that a tap of the power button during POST should be used to trigger the bluetooth keyboard mode, or a reasonable (short) timeout (say 5-10 seconds) until it continues booting without the keyboard.
Miguel_C_Old
Hi jasonv,
Intel improves the compatibility with Bluetooth devices on start up with BIOS version 0028. Check if you are already using the latest drivers.
https://downloadcenter.intel.com/search?keyword=STCK1A32WFC Drivers & Software
Your suggestion sounds great, I am going to send your comment to my supervisor; Intel stick developers are interested in customer feedback.
Mike C
Miguel_C_Old
Hi jasonv,
Mike C
