Intel® Makers
9872 Discussions
Problem with e-health v2.0 integrated with Intel Edison
KKhoi
I need to read blood pressure from a BPM monitor by using Intel Edison and an e-health sensor shield that i bought on cooking hacks . I have followed this tutor :https://www.cooking-hacks.com/documentation/tutorials/ehealth-biometric-sensor-platform-arduino-rasp... https://www.cooking-hacks.com/documentation/tutorials/ehealth-biometric-sensor-platform-arduino-rasp... . But after uploading the code into Intel Edison by Arduino IDE it appeared the following errors:
Arduino: 1.6.10 (Windows 7), Board: "Intel® Edison"
In file included from C:\Program Files\Arduino\libraries\eHealth\eHealth.cpp:41:0:
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h: In function 'void i2cInit()':
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:102:6: error: 'TWCR' was not declared in this scope
sbi(TWCR, TWEN); // Enable TWI
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:53:28: note: in definition of macro 'sbi'
# define sbi(var, mask) ((var) |= (uint8_t)(1 << mask))
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:102:12: error: 'TWEN' was not declared in this scope
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:53:51: note: in definition of macro 'sbi'
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h: In function 'void i2cSetBitrate(short unsigned int)':
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:110:6: error: 'TWSR' was not declared in this scope
cbi(TWSR, TWPS0);
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:54:28: note: in definition of macro 'cbi'
# define cbi(var, mask) ((var) &= (uint8_t)~(1 << mask))
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:110:12: error: 'TWPS0' was not declared in this scope
cbi(TWSR, TWPS0);
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:54:52: note: in definition of macro 'cbi'
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:111:12: error: 'TWPS1' was not declared in this scope
cbi(TWSR, TWPS1);
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:114:18: error: 'F_CPU' was not declared in this scope
bitrate_div = ((F_CPU/4000l)/bitrateKHz);
In file included from C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:6:0,
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:117:7: error: 'TWBR' was not declared in this scope
outb(TWBR, bitrate_div);
C:\Program Files\Arduino\libraries\eHealth\utils/defs.h:31:27: note: in definition of macro 'outb'
# define outb(addr, data) addr = (data)
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h: In function 'void i2cSendStart()':
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:56:21: error: 'DDRC' was not declared in this scope
# define WRITE_sda() DDRC = DDRC | 0b00010000 //SDA must be output when writing
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:122:2: note: in expansion of macro 'WRITE_sda'
WRITE_sda();
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:124:2: error: 'TWCR' was not declared in this scope
TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:124:13: error: 'TWINT' was not declared in this scope
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:124:24: error: 'TWSTA' was not declared in this scope
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:124:35: error: 'TWEN' was not declared in this scope
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h: In function 'void i2cSendStop()':
C:\Program Files\Arduino\libraries\eHealth\utils/i2c.h:130:9: error: 'TWCR' was not declared in this scope
TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
C:\Program Files\Arduino&#...
Community Manager
This issue seems to be related to the libraries used in the code. The libraries used in this code are compiled for different devices. I'm going to run this code and run some tests.
You can also look at this thread /message/381028# 381028 https://communities.intel.com/message/381028# 381028 , which discusses using an e-health sensor as well.
-Sergio
Community Manager
I followed the steps and as expected the IDE threw an error. This is because the libraries used by the e-health are for Raspberry Pi and Arduino, devices with a different architecture to the Edison.
I recommend you to try to write your own version of the library, based on the Arduino library code, so you can use it with the Edison.
-Sergio
KKhoi
Thanks you for your answer,I have download the library for Intel Galileo and fixed the problem
