Intel® Makers
9882 Discussions
Problem with running Galileo Gen 2
RNara2
I am new to Galileo. I am using Galileo gen 2 board. I have configured Galileo using instructions on
https://software.intel.com/en-us/iot/library/galileo-getting-started https://software.intel.com/en-us/iot/library/galileo-getting-started.
I was successful in writing the image to memory card, but when I made a serial connection using putty, it opened a terminal but nothing was displayed. Instruction said to press enter twice, I tried pressing many times but still nothing was displayed. I tried both in Ubuntu and Windows, but same problem. I have tried to make the image on two memory cards and also used two Gen 2 boards but the same problem persist.
Carlos_M_Intel
Hi rupeshnarayan
Are you using a 5V or 3.3V FTDI Cable?
Are you able to see the Serial Port in the Device Manager (Windows) or in /dev (Ubuntu)?
Did you http://http//downloadmirror.intel.com/24748/eng/IntelGalileoFirmwareUpdaterUserGuide-1.0.4.pdf update the firmware of the board?
Are you using a 2.0 or 3.0 USB port?
Which settings are you using on Putty?
In Ubuntu are you using sudo screen /dev/ttyUSB0 115200?
Are you having the same behavior when you boot with and without the SD card?
Charlie
Carlos_M_Intel
Hi rupeshnarayan,
Have you been able to open a Terminal Session with your board?
Charlie
