Hi
I want to make the example from the following page http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/d2000/enabling-dht11-humidity-sen... Intel® Quark™ MCU D2000 — Enable DHT11 Humidity Sensor: Application... ,but when I set the code, it does not compile and it shows errors.
The code is:
# include "qm_gpio.h" /*Calling QMSI GPIO API. See section 3.1 for more details. */
# include "qm_scss.h" /*Calling QMSI SCSS API*/
# define PIN_DHT11 0
int main(void) {
qm_gpio_port_config_t cfg;
uint32_t cycles[80], i;
uint8_t data[5];
typedef struct {
uint32_t direction; /* GPIO direction, 0b: input, 1b: output */
uint32_t int_en; /* Interrupt enable */
uint32_t int_type; /* Interrupt type, 0b: level; 1b: edge */
uint32_t int_polarity; /* Interrupt polarity, 0b: low, 1b: high */
uint32_t int_debounce; /* Debounce on/off */
uint32_t int_bothedge; /* Interrupt on both rising and falling edges */
void (*callback)(uint32_t int_status); /* Callback function */
} qm_gpio_port_config_t;
data[0] = data[1] = data[2] = data[3] = data[4] = 0;
QM_PUTS( "DHT11 example");
cfg.direction = BIT(PIN_DHT11);
qm_gpio_set_config(QM_GPIO_0, &cfg);
qm_gpio_set_pin(QM_GPIO_0, PIN_DHT11); /* set HIGH to DHT11 pin */
clk_sys_udelay(250000); /* 250 ms */
/* The three line above written in QMSI and are similar to Arduino's
*'digitalWrite(PIN_DHT11, HIGH);' which is to let pull-up raise data line level
* And start reading the DHT11. After that proceed with 250 ms delay.
* See section 3.4 for more details.
/* Send DHT11 start signal */
qm_gpio_clear_pin(QM_GPIO_0, PIN_DHT11); /* set DHT11 pin LOW */
clk_sys_udelay(20000); /* 20 ms */
qm_gpio_set_pin(QM_GPIO_0, PIN_DHT11); /* set DHT11 pin HIGH */
clk_sys_udelay(40); /* 40 us */
cfg.direction = 0;
clk_sys_udelay(10); /* 10 us */
uint32_t expectPulse(bool level); /*function to read DHT11 pulse*/
uint32_t count = 0;
while (qm_gpio_read_pin(QM_GPIO_0, PIN_DHT11) == level) { /*Error*/
if (count++ >= 100000) { /* 1 millisecond to read DHT11 pulse */
return 0; /* Exceeded timeout, fail. */
return count;
while (1) {
if (!expectPulse(false)) {
QM_PUTS("Timeout waiting for start signal low pulse." );
continue;
if (!expectPulse(true)) {
QM_PUTS("Timeout waiting for start signal high pulse.");
continue;
for (i = 0; i < 80; i += 2) {
cycles[i] = expectPulse(0); /* LOW */
cycles[i + 1] = expectPulse(1); /* HIGH */
// Inspect pulses and determine which ones are 0 (high state cycle count < low
// state cycle count), or 1 (high state cycle count > low state cycle count).
for (i = 0; i < 40; ++i) {
uint32_t lowCycles = cycles[2 * i];
uint32_t highCycles = cycles[2 * i + 1];
if ((lowCycles == 0) || (highCycles == 0)) {
QM_PUTS("Timeout waiting for pulse.");
continue;
data[i / 8] <<= 1;
/*Now compare the low and high cycle times to see if the bit is a 0 or 1. */
if (highCycles > lowCycles) {
/* // High cycles are greater than 50us low cycle count, must be a 1. */
data[i / 8] |= 1;
// Else high cycles are less than (or equal to, a weird case) the 50us low
// cycle count so this must be a zero. Nothing needs to be changed in the
// stored data.
}QM_PRINTF( "Receive %d %d %d %d %d\n", data[0], data[1],data[2],data[3],
data[4]);
uint8_t TempF = data[2] * 1.8 + 32;
QM_PRINTF ("h : %d, t : %d, f ; %d\r\n", data[0],data[2],TempF);
/* Check we read 40 bits and that the checksum matches. */
if (data[4] == ((data[0] + data[1] + data[2] + data[3]) & 0xFF)) {
} else {
QM_PUTS("Checksum failure!");
return 0;
The error is as follows:
Multiple markers at this line
- 'level' undeclared (first use in this function)
- each undeclared identifier is reported only once for each function it appears in
Hi ,
Can you double check that you copied in the code as described in the doc -- below compiled and ran ok for me....
--Michelle.
uint32_t expectPulse(bool level) /*function to read DHT11 pulse*/
uint32_t count = 0;
return count;
int main()
uint32_t cycles[80], i; /* same cycle number as in the DHT11 library */
uint8_t data[5]; /* same data number as in the DHT11 library */
/* Reset 40 bits of received data to zero. */
QM_PUTS("DHT11 example");
while(1){
qm_gpio_set_config(QM_GPIO_0, &cfg); /* Act like Arduino's pinMode. Setting
* DHT11 pin on D2000 dev board as input.
* See section 3.3 for more details.
*'digitalWrite(PIN_DHT11,HIGH);' which is to let pull-up raise data line level
cfg.direction = 0;
qm_gpio_set_config(QM_GPIO_0, &cfg); /* Setting the DHT11 pin as output to
* start listening from the DHT11
if(!expectPulse(false))
QM_PUTS("Timeout waiting for start signal low pulse.");
continue;
if(!expectPulse(true))
continue;
for (i=0; i<80; i+=2) {<p> cycles[i] = expectPulse(0);
cycles[i+1] = expectPulse(1);
for (i=0; i<40; ++i) {<p> uint32_t lowCycles = cycles[2*i];
uint32_t highCycles = cycles[2*i+1];
continue ;
data[i/8] <<= 1;<p> /*Now compare the low and high cycle times to see if the bit is a 0 or 1. */
data[i/8] |= 1;
// stored data.
QM_PRINTF("Receive %d %d %d %d %d\n",data[0],data[1],data[2],data[3],data[4]);
uint8_t TempF = data[2]*1.8 +32;
QM_PRINTF("h : %d, t : %d, f ; %d r\n", data[0],data[2],TempF);
else
return 0;
Hi ,
--Michelle.
uint32_t count = 0;
return count;
int main()
while(1){
cfg.direction = 0;
continue;
continue;
continue ;
data[i/8] |= 1;
// stored data.
else
return 0;
Hi MicelleC_Intel,
Now after several troubleshoot and I've got the result in serial terminal, but still the sensor not give any value to c1000.Please help me to settle this problem
(coding from PDF ENABLING DHT IN D2000, I cahnge it to C1000 availability)
# include "clk.h"
# include "qm_pinmux.h"
# include "qm_pin_functions.h"
//# include "qm_scss.h" /*Calling QMSI SCSS API*/
# define PIN_DHT22 22
# define LED_PIN_ID (QM_PIN_ID_56)
# define PIN_MUX_FN (QM_PIN_56_FN_GPIO_22)
//static qm_ss_gpio_state_t state_ss;
static qm_gpio_state_t state_ss;
uint32_t count = 0;
while (qm_gpio_read_pin(QM_GPIO_0, PIN_DHT22, &state_ss) == level)
return count;
static void pin_mux_setup(void)
qm_pmux_select(LED_PIN_ID, PIN_MUX_FN);
int main()
pin_mux_setup();
QM_PUTS("DHT22 example");
while(1)
cfg.direction = BIT(PIN_DHT22);
qm_gpio_set_pin(QM_GPIO_0, PIN_DHT22); /* set HIGH to DHT11 pin */
*'digitalWr...
right now I'm having an internship related to IoT. They gave me the C1000 to play with DHT22.
Right now I'm still cannot produce any value for Temperature and Humidity in Serial monitor.
Do you know how to read the value?
The program skip the calculation part and there is no bits that convert to Temperature and Humidity
Below is the new coding and the image attached.
# include "clk.h"
# include "qm_common.h"
# include "stdio.h"
# include "stdlib.h"
# include "stdint.h"
# include
# include
# include
# define LED_PIN_ID (QM_PIN_ID_55)
# define PIN_MUX_FN (QM_PIN_55_FN_GPIO_21)
# define MAX_INTERVAL 85
static uint8_t data[5] = { 0, 0, 0, 0, 0 };
static qm_gpio_state_t state = 1 ;//QM_GPIO_HIGH=1;
static uint8_t sizecvt(const int read)
//digitalRead() and friends from wiringpi are defined as returning a value
//< 256. However, they are returned as int() types. This is a safety function
if (read > 255 || read < 0)
QM_PRINTF("Invalid data \n");
exit(EXIT_FAILURE);
return (uint8_t)read;
static void read_dht_data(void)
static uint8_t laststate = true;
static uint8_t counter = 0;
static uint8_t j = 0, i;
static qm_gpio_port_config_t cfg;
//microseconds Minimum number of micro seconds to delay for.
//void clk_sys_udelay(uint32_t microseconds);
/* pull pin down for 20 milliseconds */
<p style="margin-bottom: 1.5em; font-family: Arial, 宋体, Ta...
