Intel® Makers
9881 Discussions
Problems Connecting 4G Modem
Community Manager
I have been trying to connect a Multitech LAT1U usb modem to intel edison. I had problems edison identifying modem. Finally I found a solution that is add serial drivers such as option, qmi_wwan, usbserial.
To include option driver, I have re-compiled the firmware.
Now I am able to recognize usb_modem but as a storage device. After going through posts, I have found that using usb_modeswitch I will not have such a problem. But in order to include , when I add IMAGE_INSTALL_append += "usb-modeswitch" to recipe file. I get an error Nothing provides "usb-modeswitch" .
Any help would be appreciated.
Message was edited by: Siva Aduri
Community Manager
Hi Siva,
Thank you for contacting us.
Regarding your project, I haven't done anything similar before, however I have found some other threads in a different Community that might be of help.
http://stackoverflow.com/questions/30861995/error-while-adding-meta-oic-layer-to-an-intel-edison-ima... http://stackoverflow.com/questions/30861995/error-while-adding-meta-oic-layer-to-an-intel-edison-ima....
Let us know if helps you.
-Pablo
Community Manager
Hi Pablo,
Thank you for the reply.
I have tried the suggestions in link you have shared, sadly It did not work.
Siva
Community Manager
Hi Siva,
Could you please provide the whole log of the error? I would like to know if there's some more information related to the usb-modeswitch error you're getting, maybe some information on its dependencies.
-Pablo
Community Manager
Hi Siva,
Last time we requested the whole log of the error you were getting. Are you still having issues with this?
-Pablo
