Intel® Makers
9881 Discussions
Problems compiling edison-src-ww25.5-15 using bitbake
PPoob
using the source edison-src-ww25.5-15, i am having problem using bitbake to compile this image, any one facing similar problems, how do i overcome this problem ?
Below i have pasted the warnings and errors.
WARNING: Failed to fetch URL http://zlib.net/pigz/pigz-2.3.1.tar.gz http://zlib.net/pigz/pigz-2.3.1.tar.gz, attempting MIRRORS if available
WARNING: Failed to fetch URL ftp://ftp.debian.org/debian/pool/main/b/base-passwd/base-passwd_3.5.29.tar.gz ftp://ftp.debian.org/debian/pool/main/b/base-passwd/base-passwd_3.5.29.tar.gz, attempting MIRRORS if available
WARNING: Failed to fetch URL http://downloads.sourceforge.net/project/libpng/libpng16/1.6.13/libpng-1.6.13.tar.xz http://downloads.sourceforge.net/project/libpng/libpng16/1.6.13/libpng-1.6.13.tar.xz, attempting MIRRORS if available
WARNING: Failed to fetch URL http://www.apache.org/dist/apr/apr-1.5.1.tar.bz2 http://www.apache.org/dist/apr/apr-1.5.1.tar.bz2, attempting MIRRORS if available
WARNING: Failed to fetch URL http://www.apache.org/dist/apr/apr-util-1.5.3.tar.gz http://www.apache.org/dist/apr/apr-util-1.5.3.tar.gz, attempting MIRRORS if available
WARNING: Checksum failure encountered with download of http://code.entropywave.com/download/orc/orc-0.4.18.tar.gz;name=orc http://code.entropywave.com/download/orc/orc-0.4.18.tar.gz;name=orc - will attempt other sources if available
WARNING: Renaming /home/prashanth/Documents/edison-src/bitbake_download_dir/orc-0.4.18.tar.gz to /home/prashanth/Documents/edison-src/bitbake_download_dir/orc-0.4.18.tar.gz_bad-checksum_2ca79043cfa8b34343436823516eca0f
WARNING: Failed to fetch URL http://www.apache.org/dist/subversion/subversion-1.8.9.tar.bz2 http://www.apache.org/dist/subversion/subversion-1.8.9.tar.bz2, attempting MIRRORS if available
NOTE: validating kernel config, see log.do_kernel_configcheck for details
WARNING: Failed to fetch URL http://fontconfig.org/release/fontconfig-2.11.1.tar.gz http://fontconfig.org/release/fontconfig-2.11.1.tar.gz, attempting MIRRORS if available
WARNING: QA Issue: bluez5: configure was passed unrecognised options: --with-systemdunitdir [unknown-configure-option]
WARNING: Failed to fetch URL git://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git;protocol=http, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 128, output:
Cloning into bare repository '/home/prashanth/Documents/edison-src/bitbake_download_dir/git2/git.eclipse.org.gitroot.paho.org.eclipse.paho.mqtt.c.git'...
fatal: repository 'http://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git/ http://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git/' not found
ERROR: Function failed: Fetcher failure for URL: 'git://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git;protocol=http'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/prashanth/Documents/edison-src/out/linux64/build/tmp/work/core2-32-poky-linux/paho-mqtt/3.1-r1/temp/log.do_fetch.4242
ERROR: Task 1052 (/home/prashanth/Documents/edison-src/out/linux64/poky/meta-intel-iot-middleware/recipes-connectivity/paho-mqtt/paho-mqtt_3.1.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1432 tasks of which 0 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 11 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
prashanth@prashanth-VirtualBox:~/Documents/edison-src/out/linux64/build$
mfu1
Hi, to solve the Paho-MQTT problem, see this thread: /thread/101227 Paho MQTT repository not found
In short, edit the file ~/edison-src/out/linux64/poky/meta-intel-iot-middleware/recipes-connectivity/paho-mqtt/paho-mqtt_3.1.bb
In the line SRC_URI do:
SRC_URI = "git://github.com/eclipse/paho.mqtt.c.git;protocol=http \
file://makefile.patch \
Best,
Tiago
BTW:I copy this from intel communities.
mfu1
Best,
Tiago
PPoob
Thanks Tiago
this solved my problem !!
sk23
New Contributor II
Hi Tiago ,
could you please update the patch or modification in code.
every time we no need to fix same issue.I will be grate help to us and new people also.
sk23
New Contributor II
Hi Tiago ,
every time we no need to fix same issue.It will be grate help to us and new people also.
