Intel® Makers
9881 Discussions
Problems to implement iptables in intel edison with yocto
nDE_S
Hi guys
I create two files:
1) in /lib/systemd/system (name:iptables.service)
[Unit]
Description=iptables
After=network.target
[Service]
ExecStart=/usr/bin/iptables.sh
Restart=always
RestartSec=10s
Environment=NODE_ENV=production
[Install]
WantedBy=multi-user.target
2) in /usr/bin (name: iptables.sh)
iptables -A INPUT -p tcp -m tcp -s neuberxxx.dyndns.xxz --dport 9999 -j ACCEPT
iptables -t nat -A PREROUTING --dst neuberxxx.dyndns.xxz --proto tcp --dport 8$
iptables -t nat -A POSTROUTING --proto udp --src 192.168.1.999 -j MASQUERADE
But after I run node.js aplication in 9999 port, The nmap command said:
nmap -p 9999 to 192.168.1.199 (LOCALHOST) - OPEN (TCP)
nmap -p 9999 to neuberxxx.dyndnz.xxz - CLOSED (TCP)
AT9
I've added ddclient 3.8.3 package into the repo per your request. I haven't modified ddclient itself to work as a service in the systemd environment (vs initV it expects), but that is "left to the reader" as they say. If you configure it as a service, feel free to submit a pull request for meta-alext-edison and I'll include it into the package.
Pedro_M_Intel
Hello neuberfran,
Is the issue appearing only when executing the service? I mean, if you run the iptables commands manually does the project work or do you have issues anyway?
If the commands work manually that might suggest that the issue is related to the service you created. I noted that on both files you did not add the line "# !/bin/sh" in their beginning. Is this just on the post or on the actual files? If this line is missing something might not work correctly.
Also, when are you trying to run a Node.JS application? Is it after boot? If so, did you enable the service?
The node application that you are running might also help, can you share it?
Peter.
nDE_S
Hi Intel_Peter,
Tnak's
https://www.youtube.com/watch?v=z3O26CC9nAc µCast # 17: Control Hardware Remotely With Socket.IO - YouTube
The node.js part (html) is work in localhost:9999 or in other pc with 192.168.1.199:9999. This based in this tutorial.
I realy forgot "# !/bin/sh" in sh.
But now it appeared a new problem (photos) after I implement services. The command : iptables -A INPUT -p tcp -m tcp -s neuberxxx.dyndns.xxxz --dport 9999 -j ACCEPT
don't work more. They were working.
Pedro_M_Intel
That output seems weird. From those messages it looks like something is consuming all of your Edison's memory and therefore the OS starts to kill all the processes running. Is there any setting you changed? I mean, you mentioned that the "iptables" command was working before but not anymore. Did you make any changes before it stopped working?
Peter.
nDE_S
Hi
Intel_Peter,
I solved this prolbem in screen. I had duplication ddclient services.
I solved iptables problem ( I guess). I said "I guess" Because I don't have more nmap in my pc (ubuntu) and node.js together.
Nowi I have problem with ddclient service. Please review the service for me:
file ddclient.service in : /lib/systemd/system
[Unit]
Description=ddclient
[Service]
ExecStart=/usr/bin/ddclient.sh
Restart=always
RestartSec=10s
[Install]
file ddclient.sh in /usr/bin
# !/bin/bash
# ddclient This shell script takes care of starting and stopping
# ddclient.
# chkconfig: 2345 65 35
# description: ddclient provides support for updating dynamic DNS services.
CONF=/etc/ddclient.conf
program=ddclient
[ -f $CONF ] || exit 0
system=unknown
if [ -f /etc/fedora-release ]; then
system=fedora
elif [ -f /etc/redhat-release ]; then
system=redhat
elif [ -f /etc/debian_version ]; then
system=debian
fi
PID=''
if [ "$system" = "fedora" ] || [ "$system" = "redhat" ]; then
. /etc/init.d/functions
PID=`pidofproc $program`
else
PID=`ps -aef | grep "$program - sleep" | grep -v grep | awk '{print $2}'`
fi
PATH=/usr/sbin:/usr/local/sbin:${PATH}
export PATH
# See how we were called.
case "$1" in
start)
# Start daemon.
DELAY=`grep -v '^\s*# ' $CONF | grep -i -m 1 "daemon" | awk -F '=' '{print $2}'`
if [ -z "$DELAY" ] ; then
DELAY="-daemon 300"
else
DELAY=''
fi
echo -n "Starting ddclient: "
daemon $program $DELAY
else
ddclient $DELAY
fi
echo
stop)
# Stop daemon.
echo -n "Shutting down ddclient: "
if [ -n "$PID" ] ; then
killproc $program
else
kill $PID
fi
else
echo "ddclient is not running"
fi
echo
restart)
$0 stop
$0 start
status)
status $program
else
if test "$PID"
then
for p in $PID
do
echo "$program (pid $p) is running"
done
else
echo "$program is stopped"
fi
fi
echo "Usage: ddclient {start|stop|restart|status}"
exit 1
esac
exit 0
in /etc/ file name: ddclient.conf
# Configuration file for ddclient generated by debconf
# /etc/ddclient.conf
protocol=dyndns2
use=web, web=checkip.dyndns.com, web-skip='IP Address'
server=members.dyndns.org
login=neuberxxxx
password='999999'
neuberfrxxx.dyndns.xxy
Pedro_M_Intel
I will take a look at it. But, it would really help if you let us know what the problem you are getting is. Can you post a screenshot?
Peter.
nDE_S
Intel_Peter,
root@neuberfran:/lib/systemd/system# systemctl status ddclient.service
● ddclient.service - ddclient
Loaded: loaded (/lib/systemd/system/ddclient.service; enabled)
Active: activating (auto-restart) (Result: exit-code) since Mon 2016-01-25 19:47:41 UTC; 622ms ago
Process: 500 ExecStart=/usr/bin/ddclient.sh (code=exited, status=1/FAILURE)
Main PID: 500 (code=exited, status=1/FAILURE)
Jan 25 19:47:41 neuberfran.dyndns.blz systemd[1]: Unit ddclient.service enter...
Hint: Some lines were ellipsized, use -l to show in full.
root@neuberfran:/lib/systemd/system# ddclient -v
-bash: ddclient: command not found
root@neuberfran:/lib/systemd/system# /usr/bin/ddclient.sh
ps: invalid option -- 'a'
BusyBox v1.22.1 (2015-06-19 07:36:41 CEST) multi-call binary.
Usage: ps
root@neuberfran:/usr/bin# ddclient.sh -v
Usage: ps
Usage: ps
e.g. CONF=/etc/ddclient.conf
program=ddclient part of the code of the file: /usr/bin/ddclient.sh.
The code ddclient.sh it will have 89 lines and not 80 or 7 lines
Pedro_M_Intel
Hi @neuberfran,
Let me see if I can understand what's happening, I'll do some tests and get back to you.
Peter.
nDE_S
Hi
Intel_Peter ,
About this topic above I need access my home network from outside I decide to use ddclient to this.
I need, frist, solution the problem with ddclient and after test iptables in edison with yocto image.
Ddclient until this moment gives the errors mentioned in my latest posts
Pedro_M_Intel
Does ddclient work when you start it manually? Is the issue only present when running it as a service?
I don't have any previous experience with ddclient. Is ddclient dependent of any other Linux service? If it is, then the service might be crashing when it finds that a dependent service is not available.
Peter.
nDE_S
Hi
Intel_Peter,
No. ddclient don't worked manually and don't worked when running it as a service.
ddclient is a perl application
I've been working with ddclient 4 years in debian with a raspberry
Do you know about perl?
Pedro_M_Intel
Then we can determine that the issue is not directly related to the service. We have to find out what's going on with ddclient before we can proceed to create a service. Try to run it manually, what's its behavior? Does it throw any error messages? What do they say?
Peter.
nDE_S
Hi/message/371665# 371665 1
Intel_Peter
To test ddclient (after instalation) in debian is easy (ddclient -v)
In yocto I followed this tutorial (https://github.com/wimpunk/ddclient GitHub - wimpunk/ddclient: Fork of the original ddclient code).
But there are differences:
One of them: cp ddclient /usr/sbin/
in yocto I put ddclient.sh in /usr/sbin/ or /usr/bin or /lib/systemd/system but don't worked
root@neuberfran:~# cd /usr/sbin
root@neuberfran:/usr/sbin# ./ddclient.sh
Usage: ps
e.g.: very important
and: in this site: https://github.com/wimpunk/ddclient GitHub - wimpunk/ddclient: Fork of the original ddclient code
I need transpose this commands to yocto
# enable automatic startup when booting
rc-update add ddclient
# make sure you have perl installed
apk add perl
# start the first time by hand
rc-service ddclient start
AT9
