Intel® Makers
9881 Discussions
Problems trying to get jsupm_grove working on Galileo Gen 1
JNagl1
I have followed the https://developer.ibm.com/recipes/tutorials/connect-an-intel-galileo-to-the-internet-of-things-found... Connect an Intel Galileo to the Internet of Things Foundation - developerWorks Recipes tutorial on connecting Galileo to Bluemix and have that working. I can run the basic .js file and send the cpu temperature to a node-red flow on Bluemix. Now I want to send sensor data from a grove kit that I have.
From this https://github.com/slkaczma/Bluemix-Intel-Edison slkaczma/Bluemix-Intel-Edison · GitHub respository I have added code added code to detect the grove board:
var groveSensor = require('jsupm_grove');
which throws an error if I try to run the file: Error: Cannot find module 'jsupm_grove'
I have tried npm install jsupm_grove which gives the following error:
npm WARN package.json ibm-iot-quickstart@0.0.1 No repository field.
npm WARN package.json ibm-iot-quickstart@0.0.1 No README data
npm WARN package.json make@0.0.0 No repository field.
npm http GET https://registry.npmjs.org/jsupm_grove https://registry.npmjs.org/jsupm_grove
npm http 304 https://registry.npmjs.org/jsupm_grove https://registry.npmjs.org/jsupm_grove
npm http GET https://registry.npmjs.org/mraa https://registry.npmjs.org/mraa
npm http 304 https://registry.npmjs.org/mraa https://registry.npmjs.org/mraa
> mraa@0.8.1 install /home/root/ibm-iot-quickstart/node_modules/jsupm_grove/node_modules/mraa
> node-gyp rebuild
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16
gyp ERR! stack at Object.oncomplete (fs.js:107:15)
gyp ERR! System Linux 3.8.7-yocto-standard
gyp ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /home/root/ibm-iot-quickstart/node_modules/jsupm_grove/node_modules/mraa
gyp ERR! node -v v0.10.25
gyp ERR! node-gyp -v v0.12.2
gyp ERR! not ok
npm ERR! mraa@0.8.1 install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the mraa@0.8.1 install script.
npm ERR! This is most likely a problem with the mraa package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get their info via:
npm ERR! npm owner ls mraa
npm ERR! There is likely additional logging output above.
npm ERR! System Linux 3.8.7-yocto-standard
npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "jsupm_grove"
npm ERR! cwd /home/root/ibm-iot-quickstart
npm ERR! node -v v0.10.25
npm ERR! npm -v 1.3.24
npm ERR! code ELIFECYCLE
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /home/root/ibm-iot-quickstart/npm-debug.log
npm ERR! not ok code 0
root@clanton:~/ibm-iot-quickstart# npm install libupm
npm http GET https://registry.npmjs.org/libupm https://registry.npmjs.org/libupm
npm http 404 https://registry.npmjs.org/libupm https://registry.npmjs.org/libupm
npm ERR! TypeError: Cannot read property 'latest' of undefined
npm ERR! at next (/usr/lib/node_modules/npm/lib/cache.js:692:35)
npm ERR! at /usr/lib/node_modules/npm/lib/cache.js:680:5
npm ERR! at saved (/usr/lib/node_modules/npm/node_modules/npm-registry-client/lib/get.js:142:7)
npm ERR! at /usr/lib/node_modules/npm/node_modules/graceful-fs/polyfills.js:133:7
npm ERR! at Object.oncomplete (fs.js:107:15)
npm ERR! If you need help, you may report this *entire* log,
npm ERR! including the npm and node versions, at:
npm ERR! <</span>http://github.com/isaacs/npm/issues http://github.com/isaacs/npm/issues>
npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "libupm"
npm ERR! type non_object_property_load
npm ERR!
I have tried npm install node-gyp and make but I still get the above errors. If I type node-gyp rebuild I get the following:
gyp info it worked if it ends with ok
gyp info using node-gyp@3.1.0
gyp info using node@0.10.25 | linux | ia32
gyp info spawn python2
gyp info s...
JNagl1
I have gotten the example to work and read sensor data into Node-Red on Bluemix using the EGLIBC image here:
https://software.intel.com/en-us/iot/hardware/galileo/downloads https://software.intel.com/en-us/iot/hardware/galileo/downloads
Instead of the one used in the above tutorial
JNagl1
