Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Problems with update partition and post_install.sh
Hello everybody,
I have some trouble with the update partition /dev/mmcblk0p9; /dev/loop0; /dev/disk/by-partlabel/update; or how you call it.
The mass storage comes not up correctly (it is not formated and has no name) using Windows or Linux.
  • I need to name that device and make it accessable to Windows and Linux
I used the Edison Board Configuration Tool to update the firmware on the Intel Edison (Firmware version installed: 201606061707).
[ 18.563981] sh[231]: Restore home/root contents on new /home partition : Success
[ 18.596204] sh[231]: Welcome to fdisk (util-linux 2.24.2).
[ 18.623243] sh[231]: Changes will remain in memory only, until you decide to write them.
[ 18.655411] sh[231]: Be careful before using the write command.
[ 18.678830] sh[231]: Command (m for help):
[ 18.703369] sh[231]: Partition type:
[ 18.719515] sh[231]: p primary (1 primary, 0 extended, 3 free)
[ 18.743195] sh[231]: e extended
[ 18.775534] sh[231]: Select (default p): Partition number (2-4, default 2): Value out of range.
[ 18.822599] sh[231]: Partition number (2-4, default 2):
[ 18.855412] sh[231]: No free sectors available.
[ 18.887189] sh[231]: Command (m for help):
[ 18.932133] sh[231]: Command (m for help):
[ 18.959143] sh[231]: Selected partition 1
[ 19.012041] sh[231]: Hex code (type L to list all codes): Changed type of partition 'W95 FAT32' to 'W95 FAT32'.
[ 19.047267] sh[231]: Command (m for help): Disk /dev/disk/by-partlabel/update: 768 MiB, 805306368 bytes, 1572864 sectors
[ 19.073691] sh[231]: Units: sectors of 1 * 512 = 512 bytes
[ 19.103428] sh[231]: Sector size (logical/physical): 512 bytes / 512 bytes
[ 19.127200] sh[231]: I/O size (minimum/optimal): 512 bytes / 512 bytes
[ 19.162166] sh[231]: Disklabel type: dos
[ 19.199085] sh[231]: Disk identifier: 0xbe3d1766
[ 19.247342] sh[231]: Device Boot Start End Blocks Id System
[ 19.287234] sh[231]: /dev/disk/by-partlabel/update1 2048 1572863 785408 b W95 FAT32
[ 19.297741] sh[231]: Command (m for help): Re-reading the partition table failed.: Invalid argument
[ 19.299766] sh[231]: The partition table has been altered.
[ 19.302168] sh[231]: Calling ioctl() to re-read partition table.
[ 19.432357] sh[231]: The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8).
[ 19.435091] sh[231]: Formatting update partition Step 1 : Success
[ 19.437099] sh[231]: Formatting update partition Step 2 : Failed ret(1)
[ 19.439176] sh[231]: No journal files were found.
[ 20.034073] sh[231]: mkfs.vfat: /dev/loop0 contains a mounted file system.
[ 20.074714] sh[231]: mkfs.vfat 2.11 (12 Mar 2005)
[ 20.106236] sh[231]: Formatting update partition Step 3 : Failed ret(1)
[ 20.172362] sh[231]: No journal files were found.
[ 20.938308] sh[231]: Formatting update partition Step 4 final : Success
[ 22.209492] sh[231]: Update file system table /etc/fstab : Success
[ 23.711607] sh[231]: Generating Wifi Access Point SSID and passphrase : Success
[ 23.773219] sh[231]: Post install success
It seems to me that it fails at diffent points (fdisk, step 2 and step 3)
All that is part of the post_install.sh script.
I also tried to build Yocto Linux http://iotdk.intel.com/src/3.5/edison/iot-devkit-yp-poky-edison-20160606.zip http://iotdk.intel.com/src/3.5/edison/iot-devkit-yp-poky-edison-20160606.zip but the result is the same.
So I did the process after updating using commands from console by hand. All commands related to post_install.sh script:
http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-edison/tree/meta-intel-edison-distro/recipes-co... meta-intel-edison - Layer for the Intel Edison Development Platform
First unmount the device because of error:
root@edison:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 1.4G 1010M 319M 76% /
devtmpfs 480M 0 480M 0% /dev
tmpfs 481M 0 481M 0% /dev/shm
tmpfs 481M 592K 480M 1% /run
tmpfs 481M 0 481M 0% /sys/fs/cgroup
tmpfs 481M 4.0K 481M 1% /tmp
tmpfs 481M 6.1M 474M 2% /var/volatile
/dev/loop0 767M 4.0K 767M 1% /media/storage
/dev/mmcblk0p10 1.3G 2.0M 1.3G 1% /home
/dev/mmcblk0p5 1003K 19K 913K 3% /factory
tmpfs 97M 0 97M 0% /run/user/0
root@edison:~# root@edison:~# df -h
root@edison:~# umount /dev/loop0
Then run fdisk but delete partition first because of error:
root@edison:~# fdisk /dev/disk/by-partlabel/update
Command (m for help): d
Partition 1 has been deleted.
Command (m for help): n
Partition type:
p primary (0 primary, 0 extended, 4 free)
e extended
Select (default p): p
Partition number (1-4, default 1): 1
First sector (2048-1572863, default 2048):
Last sector, +sectors or +size{K,M,G,T,...
Community Manager
Hello nilson,
I'll try to help you repartition your board's memory. This is a common issue that can be caused by several reasons, it is usually easy to recover from it using the flashing tools. Since you have already tried to recover your board using the setup tool, I suggest you to try the flashall method. You can find instructions on how to do it in /docs/DOC-25154 https://communities.intel.com/docs/DOC-25154.
If you'd like to change the drive's label, you could use a tools such as mlabel (https://linux.die.net/man/1/mlabel https://linux.die.net/man/1/mlabel). Nevertheless, you will have to build it from source. In order to install mlabel you have to install mtools (https://www.gnu.org/software/mtools/ https://www.gnu.org/software/mtools/) and its dependencies.
The subject of resizing the image's partitions has been discussed several times in the past, so, I'd suggest you to read the following thread and guides to learn how to do it:
/thread/55612?start=0&tstart=0 https://communities.intel.com/thread/55612?start=0&tstart=0
/docs/DOC-23449 https://communities.intel.com/docs/DOC-23449
http://alextgalileo.altervista.org/blog/changing-partition-setup-edison/ http://alextgalileo.altervista.org/blog/changing-partition-setup-edison/
I hope this information helps you.
-Peter.
Community Manager
Hello Peter,
unfortunately the flashall method did not work for me. I tried the method using Windows and Linux. Do you have any other idea regarding that problem?
Example for Linux:
sudo ./flashall.sh
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
Flashing IFWI
Download [=========================] 100% 4194304 bytes
Flashing U-Boot
Download [=========================] 100% 237568 bytes
Flashing U-Boot Environment
Download [=========================] 100% 65536 bytes
Flashing U-Boot Environment Backup
Rebooting to apply partition changes
Flashing boot partition (kernel)
Download [=========================] 100% 6144000 bytes
Flashing rootfs, (it can take up to 5 minutes... Please be patient)
Download [=========================] 100% 1400102912 bytes
Rebooting
U-boot & Kernel System Flash Success...
Your board needs to reboot to complete the flashing procedure, please do not unplug it for 2 minutes.
The result in post_install.sh at first startup is the same.
Is there a difference when using sudo ./flashall.sh --recovery? I tried to get that working with xFSTK Tools like described here:
I have following issue with that method:
Starting Recovery mode
Flashing IFWI
xfstk-dldr-solo: error while loading shared libraries: libQtCore.so.4: cannot open shared object file: No such file or directory
Xfstk tool error
DEBUG: lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
If you'd like to change the drive's label, you could use a tools such as mlabel (https://linux.die.net/man/1/mlabel https://linux.die.net/man/1/mlabel). Nevertheless, you will haev to build it from source. In order to install mlabel you have to install mtools (https://www.gnu.org/software/mtools/ https://www.gnu.org/software/mtools/) and its dependencies.
I will try the partitioning and label change (adding mtools) next week.
Thank you so far. I will post the result.
Best
Nils
Community Manager
Hi Nils,
I understand, since you have already tried both the flashall method and the Flashall.sh and pre-built xFSTK method, your best option is to submit an email to the form: https://customercare.intel.com/?lang=en-US. There we'll be able to take a closer look at your case. When filling the form, please explain that you have tried to recover your board with the Setup Tool, the flashall method and the Flashall.sh and pre-built xFSTK method.
Let me know if you receive a response.
-Peter.
Community Manager
Hello Peter,
I did not contact the customer service yet but I could solve the main problem with the update partition at the weekend.
Maybe the post_install.sh script is not working correctly in the given way. Perhaps an Yocto Intel BSP developer could verify that.
For me the following way worked well:
  1. use "df -h" to check if your update partition is mounted and use "umount" to unmount it
  2. start fdisk /dev/mmcblk0p9
    1. delete the partition (do not create a new one!!!)
    2. set the device to fat32
    3. write changes
  3. start mkfs.vfat -F 32 -n Edison /dev/mmcblk0p9
  4. reboot
Now your USB device named Edison should come up using Linux.
Windows is not working with that configuration! I will write a message when I got that.
Best
Nils
Community Manager
Thank you for updating us, please keep us aware of any news and if you have issues, please contact us back and we'll try to help you.
-Peter.
Community Manager
Hi Nils,
Do you have any updates about this?
-Peter.
Community Manager
Hi Peter,
I had no time to get deeper in touch with the problem. I hope that I will have more time next week.
But the mass storage device is also working on MAC.
I will give you an update as soon as possible.
Best
Nils
Community Manager
Hi Nils,
Thank you for letting us know, please keep us updated.
-Peter.
Community Manager
Hello Peter,
I could not manage to have a running accessible mass-storage device. When using Linux or MAC it is not necessary to create a partition. You can only formate the hole memory space with "mkfs.vfat" or "mkdosfs". Then you have a accessible mass-storage. I have a question about the process of partitioning the update memory area.
Earlier you said
Can you please show me a way from inside the Yocto Linux to make a partition that is accessible from the outside (Windows) with g_multi. What else is necessary and not mentioned in the post_install.sh. Is there a call of "dd" or some configuration that can fail. What are these several reasons?
Best
Nils
Community Manager
On my first reply when I mentioned:
"...This is a common issue that can be caused by several reasons, it is usually easy to recover from it using the flashing tools…"
I originally thought that the behavior was caused because of a software issue on the image. That's why I suggested you to flash your board with flashall. Nevertheless, as the thread developed I appeared as this was not the case.
According to your following statement (and the post it's on):
"...Now your USB device named Edison should come up using Linux.
Windows is not working with that configuration..."
It seems that your Edison is working fine but the issue might be on the Windows PC you are trying to connect to. However, the fact that you had to modify post_install.sh also makes me wonder if the image you are using is a custom image you created. If this was the case I would like that you try the following:
Flash your board with the official image ( https://software.intel.com/edison-image/latest) using the flashall method (https://communities.intel.com/docs/DOC-25154 https://communities.intel.com/docs/DOC-25154). Then check again if the drive can be found on Windows. Let us know how it goes.
If that is not the case and you were always using the official image, please let us know.
We'll be waiting for your reply.
-Peter.
Community Manager
Hello Peter,
I am working with the official sources. I only added some special python libraries and so on.
Also with an official image it is not working to have the mass-storage accessible (neither on Linux nor on Windows). To access it from Linux fdisk must be used in a different way then done in post_install.sh.
Unfortunately at this moment I have no time to go on with that issue. Maybe we can close this discussion and go on later.
Thank you for your help on that.
Best
Nils
Community Manager
I understand your situation.
Yes, whenever you can continue to troubleshoot this issue reply to this thread and we'll try to help you.
-Peter.
