Intel® Makers
9881 Discussions
Problems with using micro SD card/additional storage. Heat dissipation issue?
RRyan4
Howdy, I have recently purchased a Compute Stick (STK2m3W64CC) off of Amazon for use mainly with a living room TV and occasionally for travel as well. For the most part, I have been quite happy with it as it does everything I would like it to do, but there is one possible issue I have run into.
I have augmented the storage with a 128 GB Samsung EVO+ MicroSD card, and occasionally when running applications installed on the card or transferring larger files/folders, the card will stop responding for several minutes. I tried substituting the function of the card with a SanDisk Ultra Fit 128 GB USB 3.0 Flash Drive, but ended up running into similar issues. In fact, while transferring a few GBs worth of data to the flash drive, Windows began to chastise me for removing, inserting, and again removing the drive in rapid succession, even though the flash drive had not been touched. Upon removing the flash drive immediately following an abort of the file transfer, the USB insert was scalding hot, making me wonder if both the microSD card and flash drive are both being hampered by inadequate heat dissipation.
It should also be noted that everything on the built in storage or OneDrive continues to operate normally even while the two previously mentioned storage devices begin to have issues. After a quick internet search, it didn't look like a common issue, but it admittedly wasn't the most in depth search ever executed. Upon finding this forum, I figured this was as good of a place as any to begin searching for any possible solutions. Like I mentioned, aside from this issue, this Compute Stick has been exactly what I desired upon purchase, so a solution to this issue would remove any negatives I have experienced so far with this neat little system.
Community Manager
Hello, 1900hurricane:
I would like to gather some information in order to address this matter, so please download the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility, and attach it, with this report I will be able to confirm some of that information from your Intel® Compute Stick.
Amy.
RRyan4
Sorry for the delayed response, I was out of town for the past few days.
PLAMB2
I have something similar, although not exactly the same.
All microSD cards I have tried in the MicroSD slot are incredibly slow when writing. The same cards used in a USB adaptor work fine. The read speed is OK but the write speed is awful (kb/s when the cards are rating for 90MB/s) and even sometimes goes down to zero and never complete. With only 64GB of main disk space, using the MicroSD is an absolute must. I don't think the Compute Stick is really useful is that MicroSD port does not work. I have reinstalled drivers from the Intel site to have the latest but it did not change anything. Everything else works great but this problem is a killer.
PLAMB2
The problem was fixed today by installing the newest BIOS (June 2nd). Thanks. I now have a fully functional and very nice product !
Community Manager
Thank you for the report.
Please try updating the following drivers;
BIOS version 036: https://downloadcenter.intel.com/download/26076/BIOS-Update-CCSKLm30-86A-?product=91980 Download BIOS Update [CCSKLm30.86A], see here for the BIOS update instructions http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005961.html BIOS Update Instructions for Intel® Compute Stick, I would recommend the "F7" method.
Intel® Chipset Device Software: https://downloadcenter.intel.com/download/26055/Intel-Chipset-Device-Software-for-Intel-Compute-Stic... Download Intel® Chipset Device Software for Intel® Compute Stick STK2M3W64CC.
Intel® Management Engine Consumer Driver: https://downloadcenter.intel.com/download/26056/Intel-Management-Engine-Consumer-Driver-for-Intel-Co...
Amy.
Community Manager
I just wanted to check on this thread; were you able to install the driver mentioned above? Does the issue still persist?
Please let me know your findings.
Amy.
