Community
cancel
Showing results for
Search instead for
Did you mean:
KAror2
Program wouldn't upload on Edison ( Arduino IDE )
Hi All,
I'm using Arduino IDE to program the Intel Edison - Mini Breakout Board. In the script I'm trying to establish a connection between IBM Bluemix and Edison but it gives certain errors while uploading the script.
I've tried the following:
a) Uploading a sample program. - Didn't work
b) Uploading it through a different PC ( Mac OS ) - Didn't work
I'm attaching the error messages below. Would be grateful if anyone could help.
Kunal
Error message on Windows:
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadEdison" > $tty_port_id
C:\Users\KUNAL\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 42: /dev/ttyS4: Permission denied
# Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
C:\Users\KUNAL\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 46: /dev/ttyS4: Permission denied
# Execute the target download command
# Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
C:\Users\KUNAL\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 51: /dev/ttyS4: Permission denied
Moving downloaded file to /sketch/sketch.elf on target
# mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name# */}"
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz.exe" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" <> $tty_port_id 1>&0
C:\Users\KUNAL\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 56: /dev/ttyS4: Permission denied
An error occurred while uploading the sketch
Error message on Mac :
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: TTY port to use.
# path may contain \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
tty_port_id=$3
echo "Serial Port PORT" $com_port_id "(note: should be /dev/cu.xxxxxx for OSX)"
echo "Using tty Port" $tty_port_id
# Give the host time to stop the process and wait for download
sleep 1
"$fixed_path/lsz" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" < $tty_port_id > $tty_port_id
Retry 0: Got TIMEOUT
<p s...
Community Manager
Hi Kunal,
Thanks for your interest in the Intel Edison Platform.
I'm sorry to hear that you are having trouble uploading an Arduino sketch into the Edison. Had you already followed this guides:
- https://software.intel.com/en-us/get-started-arduino-install IoT - Installing the Arduino* IDE | Intel® Software
- https://software.intel.com/en-us/get-started-arduino-blink IoT - Blinking an LED with the Arduino* IDE | Intel® Software
If you did please let me know, also be sure that you are using your Virtual Com Port. See the image below:
I will be waiting for your reply, have a nice day!
-Jose P.
MSmor
Hi Jose
I am having a similar problem with uploading the Blink example. I just set it up using the windows 64 version of the tool and am using the Intel Virtual com port for uploading. I am also using Arduino IDE 1.8.1 with the intel Edison installed through the boards manager. Here is the exact error I am receiving:
Sketch uses 76351 bytes (0%) of program storage space. Maximum is 10000000 bytes.
# !/bin/sh
Args to shell: C:\Users\CyberPalin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\CYBERP~1\AppData\Local\Temp\arduino_build_194151/Blink.ino.elf COM24
# clupload script to invoke lsz
COM PORT 24
# Copyright (C) 2014 Intel Corporation
Converted COM Port COM24 to tty port /dev/ttyS23
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 2.1 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
# ARG 3: COM port to use.
# path contains \ need to change all to /
path_to_exe=$1
# COM ports are not always setup to be addressed via COM for redirect.
# /dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
C:\Users\CyberPalin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 42: /dev/ttyS23: No such device or address
C:\Users\CyberPalin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 46: /dev/ttyS23: No such device or address
host_file_name=$2
C:\Users\CyberPalin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 51: /dev/ttyS23: No such device or address
C:\Users\CyberPalin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 56: /dev/ttyS23: No such device or address
Mike
MSmor
Ok. Managed to solve problem by changing one of the USB cables. Now it uploads fine.
Community Manager
Hi Kunal,
I'm glad to know that you solved your issue! Please let us know if you have any more questions.
We hope you have a nice day!
-Jose P.
KAror2
Hi Jose
Thanks for getting in touch. I have been following the guide available at https://software.intel.com/en-us/node/628261 https://software.intel.com/en-us/node/628261. According to this guide, the user is suggested to identify the Serial COM Port instead of Intel Edison Virtual Com Port.
Moreover, I am unable to view any of the Intel Edison Virtual Com Port in the Device Manager.
I'd like to confirm that I had already covered all the steps mentioned in 'Installing Arduino IDE' guide.
There is one thing that I suspect could be wrong. In the guide (https://software.intel.com/en-us/node/628256 IoT - Assemble Mini Breakout Board | Intel® Software) it shows that the device would show up like this -
However, in my PC, it shows up like this -
My Edison shows up like a blank disk drive unlike the one shown in the guide.
Also to clarify that I have tried taking in MikeS's suggestion but it doesn't work for me.
Kindly suggest what to do.
Thanks and regards
Kunal Arora
Community Manager
Hi Kunal,
You don't need to worry, you are on the right track! This guide https://software.intel.com/en-us/get-started-edison-windows-32 IoT - Get Started with the Intel® Edison Development Board on Windows* 32-bit | Intel® Software should be completed before you upload an Arduino sketch into your Edison. (By the way this is the Arduino IDE guide https://software.intel.com/en-us/get-started-arduino IoT - Arduino* IDE Getting Started Guide | Intel® Software )
Now, addressing your concern regarding that you can't see your Virtual COM Port. Make sure that you are connecting your USB port, please see the image below:
If you still can't see your Virtual COM Port, please reinstall your drivers and try again.
I will be waiting for your results, have a great day!
-Jose P.
Community Manager
Hi Kunal,
Were you able to upload Arduino sketches in your Edison? Please let me know in order to assist you.
Have a nice day!
-Jose P.
KAror2
Hi Jose
Sorry for the delayed response. Some other aspects of my project kept me busy.
I'd like to confirm that when I connect to Edison using the port recommended by you i.e. the one illustrated below -
I am unable to see any ports in device manager. However, when I connect to Edison using both the port i.e. the ones illustrated below -
I can at least see the 'USB Serial Port'. I have all the initial steps covered for all other aspects of the board are usable.
Please suggest how to go further about it.
Kind regards
Kunal Arora
Community Manager
Hi Kunal,
Don't worry feel free to reply whenever you have time, we are here to help!
Now, regarding your issue where you can't see your Virtual COM. Please download again the drivers for the Intel Edison on this link https://software.intel.com/en-us/iot/hardware/edison/downloads Downloads for Intel® Edison Module | IoT | Intel® Software and follow this video https://www.youtube.com/watch?v=lDKM7UKUL5A Intel Edison Getting Started - A Step-By-Step Tutorial (windows) | Intel - YouTube in order to use the Arduino IDE with the Intel Edison.
If this doesn't work, could you please send me a screenshot of your Device Manager when you connect both your Serial port and your USB port.
Hope this helps, have a great day!
-Jose P.
KAror2
Hi Jose
Do I need to install 'Microcontroller (MCU) SDK' and 'Cross Compile SDK'? If yes, I am unable to download the 'Cross Compile SDK' for Windows 32 bit from https://software.intel.com/en-us/iot/hardware/edison/downloads Downloads for Intel® Edison Module | IoT | Intel® Software
Kind regards
Kunal Arora
Community Manager
Hi Kunal,
You only need to download the SDK if you are going to use the MCU incorporated in the Intel Edison, since your objective is to use the Arduino IDE it is not necessary to install it.
You need to download the drivers from this page https://software.intel.com/en-us/iot/hardware/edison/downloads Downloads for Intel® Edison Module | IoT | Intel® Software , or you could also use the Configuration Tool in order to install them. Please see the image below in order to understand what I'm trying to explain:
Have a nice day!
-Jose P.
KAror2
Hi Jose
Thanks for your valuable inputs. I am now able to see the 'Virtual COM Port' and upload Arduino sketches onto the board.
Kind regards
Kunal Arora
Community Manager
Hi Kunal,
I'm glad to know that you are able to see your Virtual COM! Please don't hesitate to contact us back if any questions come up.
Have a great day!
-Jose P.
