Hi Sir:
we had use the CRB(Mint Field Feb C) the boot code and flash code could be build .
On our board (D2000) . the boot code could build . but the flash code always hang up on 99%.
do you have any ideal for this ? the code is the same .
thanks ~
Tab Chiou
Hi ,
This is a Known issue in the current release of ISSM (It is mentioned in the release notes).
Please check that there are no running GDB sessions before you start flashing -
Let me know if the issue persists after all GDB sessions are closed (you can try restarting Eclipse also).
--Michelle.
Hi Michelle:
i check this issue is 32M Hz Clock not work .
we change another 32M clock is good work now .thanks ~
Tab Chiou
