Community
cancel
Showing results for
Search instead for
Did you mean:
pmanj
Programming Intel Galileo Gen2 board using Yocto linux
Jump to solution
down votehttps://stackoverflow.com/questions/46750721/intel-galileo-gen2-programming-in-yocto-linux favorite
Any expert in Intel galileo gen2 projects out there?
I am doing an assignment in which I have o program it using yocto linux. As a starting step, I am trying to glow the onboard led.
at first, I used the below commands echo "13" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio13/direction
echo "1" > /sys/class/gpio/gpio13/value
The LED did not blink Later I realised that the "13" notation on the galileo board doesnt mean that is the GPIO13 .
this notation refers to Arduino IDE not to the Linux OS libraries.
So i changed the commands with gpio7. referring the link /thread/55920 https://communities.intel.com/thread/55920
Anybody expert please helpme how can I make it work?
Also, I want to know the jumper pin connection for getting 3.3 v for I/O pins . I know I have to connect the IOREF jumper to 3,3 v pin beside it. But I am not knowing what kind of wires should I use to connect them?
Please suggest some tips.
Thanks in advance.
Regards, Poornima
Community Manager
Hi Poornima
Thanks for reaching out.
In order to configure the GPIO try the following steps:
echo 7 > /sys/class/gpio/export
echo 30 > /sys/class/gpio/export
echo 46 > /sys/class/gpio/export
echo 31 > /sys/class/gpio/export
echo low > /sys/class/gpio/gpio30/direction
echo low > /sys/class/gpio/gpio46/direction
echo in > /sys/class/gpio/gpio31/direction
To control de LED status:
echo 1 > /sys/class/gpio/gpio7/value
echo 0 > /sys/class/gpio/gpio7/value
On the other hand, you should use the IOREF jumper (no cables required) to match the operating voltage you prefer, in this case 3.3v. The IOREF pins are next to the Ethernet port.
Hope this information helps.
-Yermi A.
Community Manager
Hi Poornima
-Yermi A.
