Intel® Makers
9882 Discussions
[Project][Galileo] Webbot for showing IndieDB stats
MHöni
I just finished my project for the Intel Galileo: a webbot, which shows the current statistics of an IndieDB (http://www.indiedb.com/ http://www.indiedb.com/) project.
General description:
The webbot loads IndieDB project sites every few seconds.
Then it parses the received HTML data and shows the website hits on the connected LCD display.
A multicolor LED is used to show the current status (e.g. shines blue, when data is parsed).
When a hitcounter has increased, a laser is activated to show that.
You can reset the laser by pressing button 5.
Button 1 is to show the current hitcounters.
Button 2 is to show the onboard temperatures of the Galileo.
Hardware:
  • Intel Galileo Gen 1
  • SainSmart LCD shield
  • multicolor LED
  • Laser module
  • Cables
The multicolor LED and the laser are connected to pin 11-13 (LED is 12+13, laser is 11) via ICSP port of the LCD display.
I soldered 2 cables together to use the ground connector of the port for both, the LED and the laser.
Software:
Here is the code:
// include the library code:
# include
# include
# define NO_KEY 0
# define UP_KEY 3
# define DOWN_KEY 4
# define LEFT_KEY 2
# define RIGHT_KEY 5
# define SELECT_KEY 1
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int hitsMainLast = -1;
int hitsDemoLast = -1;
int hitsVideoLast = -1;
int mode = 0;
void setup() {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(11, LOW);
digitalWrite(12, LOW);
digitalWrite(13, LOW);
void loop() {
// read values
int value1 = getQuarkTemp();
int value2 = getADCTemp();
int key = getKey();
// change mode
switch (key)
case 1:
mode = 0;
break;
case 2:
mode = 1;
break;
case 3:
break;
case 4:
break;
case 5:
break;
// get data from the internet
int hitsMain = GetHits("curl http://www.indiedb.com/games/nightork-adventures-beyond-the-moons-of-shadalee http://www.indiedb.com/games/nightork-adventures-beyond-the-moons-of-shadalee", "stats", 72, 77);
delay(500);
int hitsDemo = GetHits("curl http://www.indiedb.com/games/nightork-adventures-beyond-the-moons-of-shadalee/downloads/nightork-adv... http://www.indiedb.com/games/nightork-adventures-beyond-the-moons-of-shadalee/downloads/nightork-adv...", "Statistics", 163, 173);
delay(500);
int hitsVideo = GetHits("curl http://www.indiedb.com/games/nightork-adventures-beyond-the-moons-of-shadalee/videos http://www.indiedb.com/games/nightork-adventures-beyond-the-moons-of-shadalee/videos", "Statistics", 178, 188);
if (hitsMain != hitsMainLast || hitsDemo != hitsDemoLast || hitsVideo != hitsVideoLast)
digitalWrite(11, HIGH);
hitsMainLast = hitsMain;
hitsDemoLast = hitsDemo;
hitsVideoLast = hitsVideo;
// display text:
lcd.clear();
switch (mode)
case 0:
lcd.setCursor(0, 0);
lcd.print("NA:BMS");
lcd.setCursor(8, 0);
lcd.print("M:");
lcd.setCursor(10, 0);
lcd.print(hitsMain);
lcd.setCursor(0, 1);
lcd.print("D:");
lcd.setCursor(2, 1);
lcd.print(hitsDemo);
lcd.setCursor(8, 1);
lcd.print("V:");
lcd.setCursor(10, 1);
lcd.print(hitsVideo);
break;
case 1:
int qTemp = getQuarkTemp();
int adcTemp = getADCTemp();
lcd.print("Q-T:");
lcd.setCursor(7, 0);
lcd.print(qTemp);
lcd.print("ADC-T:");
lcd.setCursor(7, 1);
lcd.print(adcTemp);
break;
delay(2000);
// Read Hits
int GetHits(const char* url, const char* indicator, int first, int last)
// create buffer
char output[1000];
for (int i=0; i<1000; ++i)<p>  output[i] = 0;
// fetch
digitalWrite(12, HIGH);
