Community
cancel
Showing results for
Search instead for
Did you mean:
MVert1
PuTTY Terminal no response with Galileo Gen 2 Board
We are connecting to the Galileo board using PuTTY. It appears to connect, but when I try to type anything in the command-line, there's no response.
The documentation for starting up the session says to hit enter twice to get to the login. When I hit enter, nothing happens.
When I hit reset on the Board itself, I get a short string of numbers and characters on the command-line so there must be the communication between the board and my terminal.
We are using a USB to micro-USB cable to connect the board to my Windows 8.1 computer.
It's connecting on COM3 at speed 115200.
Why am I unable to type anything in the PuTTY command window? Is there a better terminal to use for this than PuTTY?
JHrib
New Contributor II
Putty works fine for me. But if you want there are many alternatives. Termite, TeraTerm, Screen, etc..
I think you should first check if COM3 really is the port where your device is. Second to connect directly to Galileo you need serial cable:
Cheers
Diego_V_Intel
Hi Micahz,
The serial cable you have to use to get access to the terminal is shown here: http://www.intel.com/support/galileo/sb/CS-035124.htm Intel® Galileo Boards and Kits — Console Serial Cables
Diego.
DElBa
i have this problem also in galileo gen 1
MJala
I am using intel Galileo Gen1 and when I connect to putty and press enter twice nothing happens and I don't see the prompt in the black screen. Any idea why is that?
I am following this tutorial:
https://software.intel.com/en-us/articles/getting-started-with-the-intel-galileo-board-on-windows Set Up Serial Terminal on the Intel® Galileo Board for Windows* | Intel® Developer Zone
Diego_V_Intel
Please make sure that there is a COM port assigned to your Galileo board when the serial cable is connected. In the Device Manager you can check it. Additionally, make sure that the baudrate selected is 115200.
Have you updated the firmware of the board? You can use the Firmware Updater Tool available here: http://www.intel.com/support/galileo/sb/CS-035101.htm Intel® Galileo Boards — Software Downloads.
Diego.
MJala
Hi Diego,
COM7 is assigned and I have checked in device manager and there was no problem. Also the baudrate I had selected is 115200. Do I need just to connect the microSD to USB cable besides the power or do I also need to connect the audiojack to USB cable for serial RS232 communication? (or just the audiojack to USB and not the MicroSD to USB besides?) I wonder if there is a video that can walk me through this process?
Also I had updated my firmware successfully and there was no problem with that.
MJala
The way I solved it was using the AudioJack to USB along with MicroUSB to USB and use the COM port number for the AudioJack to USB instead. I have attached a photo which explains further. Using only the MicroUSB to USB or using its port number didn't work in my case.
JHrib
New Contributor II
That's because you can connect using putty only with serial cable. When you use only micro USB cable, you can only load Arduino sketch to the board. The tutorial which link you posted is quite clear regarding this. For Gen 1, install the drivers that should have been provided with your serial to USB converter from the manufacturer....
Cheers, Jernej
Diego_V_Intel
Hello MonaJalal,
I found the following video that shows how to set up the serial connection with the terminal: https://www.youtube.com/watch?v=qh66UZepJP0 Setting Up a Serial Connection on a Gen 1 Intel® Galileo Board - YouTube. I hope you find it useful. Additionally, the following guides might be interesting for you to check:
Diego.
rthat
i have same problem also in galileo gen 2
