Community
cancel
Showing results for
Search instead for
Did you mean:
FFahd
Pulse/Oximeter for the Galileo.
So after searching through the Galileo compatible sensors I could find an oximeter(oxygen saturation level) sensor for an upcoming project. There are compatible pulse sensors however they only measure pulse. I was wondering if there was any sensor similar to the MAX30100 Pulse/Oximeter. Has anyone used this sensor before? Or is anyone able to tell me if it will work properly. A lot of the sensor I have right now don't work properly with the Galileo.
One more thing, I have a DHT21 humidity/temperature sensor and I have heard from several people that the DHT line up does not work with the Galileo. Are there any alternative two in one humidy/temperaure sensors in a nice housing.
FTinetti
Honored Contributor I
I'd like to know the sensors you have, at least for documentation purposes.
I don't know about DHT21, but it seems to be some workaround/s for DHT22:
HTH,
Fernando.
Community Manager
Hi FShiwani,
Did you check FGT's suggestion? Do you still have questions about this?
-Pablo
