I tried making a Python Blink Example.
# -*- coding: utf-8 -*-
import os
import os.path
import time
# --Special thanks to--
# http://www.emutexlabs.com/component/content/article?id=203:getting-started-with-intel-galileo-gen-2 http://www.emutexlabs.com/component/content/article?id=203:getting-started-with-intel-galileo-gen-2
# -->4.3 Pin configuration options for Galileo Gen 2
# /message/249663# 249663 https://communities.intel.com/message/249663
# Blink example for Intel Galileo Gen 2
# This example wil blink led 13 (=GPIO 7) on the Intel Galileo Gen 2
# Pin 13 is located near the full size USB port
def init():
pinsetup('46','out','0')
pinsetup('31','out','1')
pinsetup('30','out','0')
def pinsetup(pinexp,pindir,pinval):
strexport=("echo \"%s\" > /sys/class/gpio/export" % pinexp)
strdir=("echo \"%s\" > /sys/class/gpio/gpio%s/direction" % (pindir,pinexp))
strval=("echo \"%s\" > /sys/class/gpio/gpio%s/value" % (pinval,pinexp))
# os.system("echo \"46\" > D:\TEST.TXT") ;
os.system(strexport) # write a "30" to the export file, which reserves gpio30 for use
os.system(strdir) # sets gpio30 as an output
os.system(strval) # sets gpio30 low, enable dir_out
print strexport
print strdir
print strval
def pinHLDir(pinexp,pindir,pinval):
def pinHL(pinexp,pindir,pinval):
init()
while(1):
pinHL('7','out','1')
time.sleep(2)
pinHL('7','out','0')
time.sleep(2)
I get this output.
/bin/sh: line 0: echo: write error: Device or resource busy
echo "46" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio46/direction
echo "0" > /sys/class/gpio/gpio46/value
echo "31" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio31/direction
echo "1" > /sys/class/gpio/gpio31/value
echo "30" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio30/direction
echo "0" > /sys/class/gpio/gpio30/value
How do i get rid of the error?
- Tags:
- Python
Hi BrechtW,
Given the message, it is possible that the GPIO pin that you're exporting is already exported. Did you make sure that this is not the case?
PabloM_Intel
How can i check if the pin is already exported in python code, so I can avoid this error?
Hi BrechtW,
It should be possible to write a program that reads within the file and checks if the pin has already been exported. However, you can first check it using Linux, if you determine that this is actually true and that the pin is already set it won't be necessary to write a program to check this. Your code should run fine even with this message ("Device or resource busy").
PabloM_Intel
It works with the error, but now I check if the directory already exists.
import os
import os.path
import time
# http://wiki.ros.org/IntelGalileo/IntelGalileoGPIO http://wiki.ros.org/IntelGalileo/IntelGalileoGPIO
def init():
# Use GPIO table from right to left
# pinSetup('46','out','0') # Mux H/L: L
# pinSetup('31','out','0') # Pull up/down: pull-down
# pinSetup('30','out','0') # Direction out/in: output
# pinDir('7','out') # GPIO pin
pinExport('46')
pinExport('30')
pinExport('31')
pinExport('7')
pinHL('30', '0')
pinHL('31', '0')
pinDir('7', 'out')
# if this doesn't work comment these out and use the code out at the beginning of init() in comments
def pinSetup(pinexp, pindir, pinval):
if os.path.exists("/sys/class/gpio/gpio%s" % pinexp) == False:
strexport = ("echo \"%s\" > /sys/class/gpio/export" % pinexp)
os.system(strexport) # write a GPIO number to the export file, which reserves it for use
print strexport
else:
print "INFO: GPIO %s already exists, skipping export" % pinexp
strdir = ("echo \"%s\" > /sys/class/gpio/gpio%s/direction" % (pindir, pinexp))
strval = ("echo \"%s\" > /sys/class/gpio/gpio%s/value" % (pinval, pinexp))
os.system(strdir) # sets GPIO as an output/input('out'/'in')
os.system(strval) # sets GPIO high/low('1'/'0'), enable dir_out
print strdir
print strval
def pinExport(pinexp):
print strexport
else:
def pinUnExport(pinexp):
strunexport = ("echo \"%s\" > /sys/class/gpio/unexport" % pinexp)
os.system(strunexport) # write a GPIO number to the unexport file, the pin can now be used by something/someone else
print strunexport
def pinHLDir(pinexp, pindir, pinval):
# first %s is replaced with first parameter, second %s is replaced with second parameter
# print strdir
# print strval
def pinDir(pinexp, pindir):
# print strdir
def pinHL(pinexp, pinval):
print strval
init()
while (1):
pinHL('7', '1')
time.sleep(2)
pinHL('7', '0')
time.sleep(2)
