Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Qaurk x1000 BIOS Flash selection clarification
Hi Team,
In one of our quark x1000 based custom design we have used W25Q64FVSSIG (IC FLASH 64MBIT 104MHZ 8SOIC) flash for BIOS,due W25Q64FVSSIG Flash part EOL we would like to go with the new available part which is W25Q128FVSIG-ND (IC FLASH 128MBIT 104MHZ 8SOIC) .Could you please check and let us know whether we can replace this part with the above specified part or not.If not please provide us the suitable BIOS flash parts or vendor details and also provide the details if there is any specific requirements in selecting the BIOS flash for Quark x1000.
Narendra
Community Manager
Hi MNKR,
Thank you for contacting us. We looked at the product attributes of both chips you mention and as you pointed out, the main difference is the memory size. The document that lists the considerations you should take while designing with the Quark X1000 is the PDG, which can be found here: http://www.intel.com/content/www/us/en/embedded/products/quark/quark-x1000-platform-design-guide.htm... http://www.intel.com/content/www/us/en/embedded/products/quark/quark-x1000-platform-design-guide.htm...
The SPI Flash Design Guidelines can be found in Section 11.
In the description you can see that: "Each SPI flash device can be up to 64 Mbytes (512 MBits)". These 64 Mbytes is the memory size of the W25Q64FVSSIG. I believe the upgrade you want to perform won't be possible, because the memory size of the flash you want to use exceeds the value listed in the PDG. Please take a look the section mentioned, for the guidelines on how to choose a memory that works with your Quark X1000.
At the end of section 11 you can see a list of serial flash vendors in case you want to consider additional devices.
Let us know if this answers your question.
-Sergio A
Community Manager
Hello Serigo,
For your information W25Q64FVSSIG is 64Mbit not 64Mbyte.I hope as per your suggestions W25Q128FVSIG-ND (IC FLASH 128MBIT 104MHZ 8SOIC) meets the requirement.
Narendra
Community Manager
Hi MNKR,
I reviewed the datasheet of both the W25Q64FVSSIG and the W25Q128FVSIG-ND and you're right, the W25Q64FVSSIG is 64MBIT and the W25Q128FVSIG-ND is 128MBIT, not Mbyte. I apologize for the confusion. In that case, it seems that the W25Q128FVSIG-ND meets the guidelines established in the PDG. I apologize once again for the confusion and let us know if there's anything else we can assist you with.
-Sergio
Community Manager
Thanks Serigo for confirmation.I will get back to you if there are any other clarifications.
Narendra
Community Manager
You're welcome @Narendra. We're here to help in any way we can. Don't hesitate to contact us again if help is needed.
-Sergio A
Community Manager
Hi Serigo,
We don't see W25Q128FVSIG-ND part in quark software source files.
BIOS code of Quark supports only below parts.
Supported SPI Flash Devices:
SpiFlash25L3205D // Macronix 32Mbit part
SpiFlashW25Q32 // Winbond 32Mbit part
SpiFlashW25X32 // Winbond 32Mbit part
SpiFlashAT25DF321 // Atmel 32Mbit part
SpiFlashQH25F320 // Intel 32Mbit part
SpiFlash25VF064C // SST 64Mbit part
SpiFlashM25PX64 // NUMONYX 64Mbit part
SpiFlashAT25DF641 // Atmel 64Mbit part
SpiFlashS25FL064K // Spansion 64Mbit part
SpiFlash25L6405D // Macronix 64Mbit part
SpiFlashW25Q64 // Winbond 64Mbit part
SpiFlashW25X64 // Winbond 64Mbit part
SpiFlashQH25F640 // Intel 64Mbit part
Could you please check and let us know how to use W25Q128FVSIG-ND for our project?
Narendra
Community Manager
Hi Narendra,
We've sent you a private message, please check your inbox.
-Sergio
