Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Quadcopter w/ Intel Edison
I've recently programmed the autopilot for my Arduino quadcopter.
I'd like to migrate to Intel Edison but I need to know some things.
1) is there an easy way to communicate point-to-point (For example PC -> Intel Edison) using WIFI without having unbearable delays?
2) I need a PWM library where I can set the PWM period, in my case less than 5ms.
3) Are there I2C and SPI libraries?
thank you for your support
Highlighted
Honored Contributor I
Re: Quadcopter w/ Intel Edison
Highlighted
Ashish D. wrote:
For questions 2 and 3 please see https://github.com/intel-iot-devkit/mraa https://github.com/intel-iot-devkit/mraa
thank you for the answer!
So now I only need to know if Edison's WIFI can acts as Access Point
Highlighted
Please refer to this doc: /docs/DOC-23137 https://communities.intel.com/docs/DOC-23137
Highlighted
Thank you.
I just completed an Arduino Yun Wifi-based quadcopter . Next step an Edison one !
